ksumnole
2025 R1T TriMax
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio IMG_4490
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio IMG_4491
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio IMG_4492
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio IMG_4493
Photos of the OEM "sub".
This is pretty much what I saw earlier when I looked at a few eBay listings. To use that 6x9 as a passive radiator, I think one would have to gut out the interior of the enclosure, modify the flat top to include a mounting face for the 8” sub.
Without benefit of touch, that 6x9 sure look like inexpensive pressed fiber material. A polymer one should perform better, without getting to expensive composite ones.
brij patel
brijesh
houston
2025 r1t
quick question can we just swap sub with meridian sub from ebay? would it improve?
Doubtful. Looking at pictures on eBay I don't see any differences between the hardware, other than the logo. Any difference in sound would be the audio processing, which is software. You are more likely to see improvement in switching out the 6x9 driver itself, wrapping the enclosure or lining vehicle structure around it with anti-vibration mat, and (if possible) stuffing the inside of the enclosure with some poly fill.
ksumnole
2025 R1T TriMax
Question. If I line the vehicle structure with an anti-vibration mat, the amp will technically be inside the sub enclosure. Do you foresee any issues there?
Should be fine
ForeverWild
Phoenix Arizona
2023 Rivian R1T Quad Large
Only issue would be if you inhibit air circulation needed for effective amp convection cooling.
DuoRivian
Rivian R1T and an R1S
Thanks for finding this, so there is a possibility for a fairly straightforward swap?
It would be, if and only if... and I do not know answers.
  • There is enough room inside the factory enclosure to fit this 6x9 MMATS sub?
  • The factory sub channel is powerful enough to drive this sub (which is 300W RMS)?
Tempted to look for a salvaged sub to investigate. But... would feel a lot better taking that plunge if I knew factory power for that channel.
It's got a big ass driver. I am not sure it will fit.
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio Screenshot 2025-05-18 at 7.01.46 PM
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio Screenshot 2025-05-18 at 7.02.51 PM
Rivian R1T R1S 2025 R1T Tri Max - Subwoofer Replacement - Upgrade to Premium Audio Screenshot 2025-05-18 at 7.18.05 PM
ForeverWild
Phoenix Arizona
You’ll also need oem speaker impedance compared to this subs impedance. Is the OEM sub a single voice coil (more than likely)
Correct. Many suspect it's 4Ω, but not confirmed.
cohall
2022 Rivian R1T
If anyone is interested, shockingly this seems to be the only 6x9 sub on the market. Not sure it would fit as a direct replacement. How many watts is the factory sub channel? Anyone know?
https://garagebaggerstereo.com/products/mmats-pro-audio-mbw690-6x9-subwoofer
What about this? Seems to be designed for free air use, and with a relatively shallow mounting depth requirement.
https://www.cdtaudio.com/cdtnew22/products/components/woofers/cl69subcf.php
Caveat: I have literally zero knowledge about car stereo components, so I could be way off
