kizamybute'
- Joined
- Oct 17, 2021
- Threads
- 80
- Messages
- 1,180
- Reaction score
- 1,997
- Location
- Los Angeles
- Vehicles
- This one, that one and the other one.
- Thread starter
- #61
EDITED ORIGINAL POST TO INCLUDE THE FOLLOWING REGARDING TPMS.....
RE: TIRE PRESSURE MONITOR SENSOR NOTED IN ORIGINAL POST.........BUYERS BEWARE!
EDIT: 02/06/2023 - DUE TO FEEDBACK FROM OTHER BUYERS AM TAKING THIS OFF MY RECOMMENDED LIST. WHILE I WAS ABLE TO SUCCESSFULLY GET A SET OF SENSORS WORKING ON MY TRUCK, THEY ARE FINICKY AND REQUIRE A PROGRAMMING TOOL TO GET THEM WORKING. NEED TO MAKE SURE YOUR TIRE SHOP HAS AN UPDATED PROGRAMMING TOOL THAT INCLUDES THE RIVIAN CODES. ASK IN ADVANCE. SO FAR, IT APPEARS THAT MOST DO NOT. MANY SENSORS REQUIRING ACTIVATION (NOT PROGRAMMING) WHICH IS THE CASE WITH THESE AS WELL. SOME SENSORS ARE SIMPLE PLUG AND PLAY, THESE ARE NOT. SOONER OR LATER, MOST TIRE SHOPS WILL GET THEIR PROGRAMMERS UPDATED TO INCLUDE THE RIVIAN ACTIVATION CODES, BUT SINCE MOST APPARENTLY STILL DON'T HAVE THEM, IT CAN MAKE IT DIFFICULT TO GET THEM TO WORK AND THERE'S A VERY DETAILED PROCESS REQUIRED TO DO SO IF IT DOESN'T WORK THE FIRST TIME.
NOT REMOVING FROM MY RECOMMENDED ITEMS SOLELY BECAUSE OF THIS, BUT APPARENTLY TPMS247 HAS BEEN SLOW TO RESPOND TO CUSTOMERS, WHICH TO ME, IS UNACCEPTABLE. ANY COMPANY SHOULD OPENLY COMMUNICATE WITH THEIR CUSTOMERS AND DO ALL THEY CAN TO MAKE SURE THE PRODUCT WORKS WITH THE LEAST AMOUNT OF EFFORT FROM THE CUSTOMER. BASED ON FEEDBACK FROM MULTIPLE CUSTOMERS, TPMS247 HAS FAILED IN THIS RESPECT.
WHILE THEY DO SELL SENSORS THAT WILL WORK, PROCEED WITH CAUTION AT YOUR OWN RISK IF YOU CHOOSE TO DO SO. MOST IMPORTANTLY, MAKE SURE YOU HAVE ACCESS TO A PROGRAMMER TOOL, OR THAT YOUR TIRE SHOP HAS ONE UPDATED WITH THE RIVIAN CODES SO YOU CAN "ACTIVATE" THE SENSORS. IF YOU DO, THEN YOU SHOULD BE FINE. IF YOU DON'T, THEN IT COULD BE A STRUGGLE TO GET THE NECESSARY ASSISTANCE OR DIRECTION FROM TPMS247.
