All wheel inflation - for cheap
Polar
C40, LE CY R1S
Picked up a cheaply made 4 tire inflator with locking closed flow chucks - and it’s working great and is super compact due to the small cheap vinyl hose. I’m in $40 for this - which is a quarter the cost of other off-road inflation kits. It’s also long enough - it would have cost more in parts to source this myself.
-This is the kit I purchased
It took a bit of modification to fully convert it to standard quarter inch disconnects - but I was able to add my in-line analog pressure gauge to validate all tires can be aired up or aired down to the same pressure at the same time.
Rivian R1T R1S All wheel inflation - for cheap IMG_0384
Rivian R1T R1S All wheel inflation - for cheap IMG_0393
The lines split from a central T to a second T on each side that then runs to the passenger/driver wheels.
Rivian R1T R1S All wheel inflation - for cheap IMG_0398
Rivian R1T R1S All wheel inflation - for cheap IMG_0401
Polar
Polar
C40, LE CY R1S
Why not use the compressor that comes with the truck?
I am using the OBC - this allows me to inflate all four at once without having to move the chuck each time and lets me lower the pressure for off-road needs.
Rivian R1T R1S All wheel inflation - for cheap IMG_0388
jjswan33
Joshua
Sandy, OR
I think we have all had enough with the inflation... and it definitely isn't cheap
bad jokes aside, nicely done
WSea
Patrick
West seattle
R1T, Outback
Architect
+1 for all tire inflation/deflation. Didn't see the value at first. Got the Thor's with the 8' extension and no longer need the riv hose
Polar
Polar
C40, LE CY R1S
100% next step is a 3’ hose as a lead between OBC and my trigger - then the Rivian hose will be an emergency only backup.
Seeing what the Thor kit cost and other “FourBy” kits cost is what drove me this direction.
foxerson
San Francisco
'10 Outback, '11 328i, '23 R1T
Very cool. I had been eyeing cheap 4-tire inflation options and had picked this one for my Christmas wish list.
I've got a similar setup, but have discovered it takes too long to fill my aftermarket 20s from 25 psi up to the 60psi I drive with on-road. Still considering upgrading the compressor but haven't done anything about it yet.
Brewbud
I made a similar setup a few years ago. Mine does two at a time though. Up until I got the R1T I never ran the same tire pressure in all four tires. It also made the storage size a little smaller.
WSea
Patrick
West seattle
R1T, Outback
Architect
Insanely long and the quick connect is almost too hot to touch
