Anyone know when Rivian switched to the new "front" subframe?*edit*
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
These pictures are from a mid december built 2023 R1T and 3/24/23 built R1S. Front subframe with welded components is from an R1T and the fully cast subframe is from a newer R1S.
So what you're saying is this, right?
Rivian R1T R1S Anyone know when Rivian switched to the new "front" subframe?*edit* 1684299220066
Killer95Stang
Killer95Stang
Dan
Sunny Socal
Not necessarily good and bad, but new and old.
I agree with you... not good nor bad. I'm sure that part has gone through multiple revisions. Plus, most racecars probably share the construction method of the welded piece, over the cast piece.
Agree on cast vs. properly welded, but those welds are clearly hand welded, and pretty darn sloppy, which may or may not affect the integrity.
crashmtb
Man oh Manitoba
Hot metal glue gun
SASSquatch
Washington DC
BMW i3s Ford C-Max Hybrid
Semi-Autonomous Yeti
But does the Rivian with the welds have the plastic inserts in the back of the headrest or the wooden ones?
The structural integrity of the entire vehicle depends on it!
zefram47
R1T, C6 Corvette GS
ive got a 19xxx VIN R1T, manufacture date of 2/23 and it has the cast subframe same as the photos OP posted. was a bit relieved to see that.
My 199xx R1T also in 2/23 has the newer cast LCA and revised spindle as well.
Jason
Jason
Austin
2022 Canyon Red R1T, 2022 Blue Model Y,
Software Engineering Manager
I have the older subframe and the truck is making a bad popping sound when I turn. Has anyone experienced any catastrophic failure of these welded joints?
Rivian replaced one of my dampers for popping during low speed turns and when going over thresholds.
Jason
Jason
Austin
Zero is the lowest speed it would pop at. I don't have sound on this computer for your video.
The subframe was Rivian's diagnosis, not mine. I initially thought it was a loose steering rack.
Quick
CT
I took my R1T in for alignment issues. They ended up replacing the subframe and lower control arms. I had the welded subframe to start, and they replaced it with the welded version as well. VIN 14XXX
Rob O
Bend, OR
2023 R1T, 2019 RS5 Sportback, 2018 Raptor, 2020 M4
Dad
Mine must have just missed the change over … 1/23 build, mid-18000 VIN and welded
Rivian R1T R1S Anyone know when Rivian switched to the new "front" subframe?*edit* IMG_6280
Z16DNA
Kevin
Beaverton Oregon
'22 Gladiator Rubicon Diesel, '04 Corvette ZO6
Business Owner
I have a March 31st '23 build date. Has the updated Front Cradle.
