jjswan33
- Thread starter
- #1
Hey All. Looking for thoughts ideas on mounting a canopy to the R1T bed. I know there have been multiple discussions on mounting a cab height bed rack and some of those strategies might be applicable but looking for help from the hive mind and to formulate a good strategy.
So looking into the structure of the bed sides I am seeing. On top is the plastic cover. You have the cross bar attachment points that go through the tonneau track assembly and then into the structure of the truck. Then there is the tonneau track assembly that appears to be made of some kind of aluminum alloy, appears to be 1/16ā thick. The C channel that the tonneau runs in is tubular and attaches on the top at least in 5 places (2 each where the cross bars attach and at least one more in the center. Below the C channel the aluminum continues down into the bed about 4ā and then there is the 3 screws that go through that where the bed side plastic material attaches, based on the length of the screws I donāt think it attaches to the frame here but didnāt take it apart enough to see.
So thoughts:
1. I have seen some reports of people adding L/S track to the three attachment points on the side, I could potentially do this and then clamp to that rail but with the size/length of those screws I am not real confident that would be sufficient.
2. Attach directly to the cross bar mounting points or the area where those mount to the vehicle
3. Clamp directly to the tonneau track. Seems the easiest and I believe the assemble itself is easily attached well enough to the truck but is tubular aluminum (1/16ā) thick enough to hold.
Here are the photos I took while I had it apart.
So thoughts:
