Charging door not opening via touch
johstacy
I have this random issue and I was wondering if anyone else is experiencing this. Once in a while (seems more lately) my charging door will not open when you touch the 3 lines no matter what I do. To get it to open I have to into the infotainment center and open if from there. but when I do that the door will not close by touch again I have to into the infotainment center and close it from there.
Anyone else experience this or know why it is happening?
Mine will do this sometimes as well, but mine always seems to fail when closing.
ccmun
Silva
Florida
Model Y, R1T, KTM 1290
Tech Consulting
Happened to me a few days ago. Soft reset solved the issue.
VSG
R1T LE/RB/OC/20
Just a guess, but if a reset doesn't fix it maybe the ground wire for the capacitive sensor is loose. Regardless, easiest to just try a soft reset, then a hard reset if that doesn't work, then make an appointment with the service center if you're still seeing the problem.
johstacy
johstacy
a soft reset is easy enough... are you saying this could be a software issue (bug) (feature). I doubt it is hardware related as it works most of the time.
VSG
R1T LE/RB/OC/20
If there were a "loose connection" it would work some of the time and would fail some of the time. It doesn't hurt to do the reset - customer service would ask you to do that anyway as part of the diagnostic process. The goal is to get it working again, and a reset is something you can do yourself that might work without a service center appointment. But I think it's more likely that there's a hardware problem.
888tom888
Malibu
Tesla Model 3 Performance
Self Storage
I had this happen to me for a few days. Just as I was going to take it in for service (pain in the ass drive to El Segundo) it started working. In the interim, I did a soft reset as well. Working like a charm since then.
Shzeph
Zak
Renton, WA
Student
Mine did this a few times after being out in the cold and snow and such. It always started working again when the truck had sat in the garage for a little. I assumed it was because the capacitive sensor (which is how I think the exterior switch works) was too cold to read my finger or whatever
VSG
R1T LE/RB/OC/20
Cold isn't a problem for capacitive sensors but moisture is - moisture build up in the field of the sensor can affect the reading, which is why car wash mode disables the sensor to prevent the charger door from opening.
DJG
TX
Various
Does it happen after it has been sitting awhile (several hours)?
Mine does this when the vehicle is in a deep sleep. A quick open/close of one of the cabin doors and the capacitive button wakes up. If it was locked, I'd think an unlock from the app would also achieve the same end.
johstacy
johstacy
I have let it sit for about an hour then walked back out and tried it again with no luck however some have mentioned water or cold of both I have in spades at the moment. when I have time I will go out and try the soft reset to see if the resolves the issue.
Shzeph
Zak
Renton, WA
Student
Ah, well, at least around here the cold came with a lot of wetness. So guessing that was probably it then
(Thanks for the explanation. I have zero clue how capacitive sensors work 😅)
Craigins
Chicago Suburbs
Software engineer
Like others, I've had it happen once in the cold and wet. Seems to be a common theme.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
Sometimes the sensor seems very sensitive, sometimes I have to slide my finger across it multiple times.
something else I noticed recently. The charge door will occasionally open slower than usual. Has anyone else noticed this? Makes me paranoid about my 12V…
DJG
TX
Various
Try simply opening the door and closing it to wake up the truck. My truck will sometimes enter a deep sleep within 30 minutes of getting home, for example, when it was a long drive and it assumes I'm done for awhile.
