hobbyjogger71
Per the hot thread in this sub-forums, "The Preconditioning Myth" - I don't think any of that last statement is true, or at least with the definitive truth you speak. I have never seen my Emporia charger report power being pulled unless the car is below the trigger and charges up to meet it.geez….is not overly ambiguous. It is common knowledge that EVs suffer from “phantom drain”, which is more particularly pronounced in the extreme cold…..so even if you are not actively charging, if your battery drops below the set point, it will start to charge again, and warm the battery to some degree.
Additionally, if you are in the habit of warming up your vehicle before departing, and it is plugged in, the HVAC will pull from the charger rather than the vehicle, and the battery is warmed as well (neither of which occur if you heat the vehicle and it is not plugged in).
The truck never pulls shore power - it's the battery that is then topped off. That setting is only giving it permission to top off should you be outside of a charge window (for TOU reasons).
