Color-Matched Vinyl
camaroz1985
Carlisle, PA
R1T, ID.4
Just wanted to share, in case anyone is looking for vinyl to match different parts of your truck.
Oracal Golden Yellow 651 is pretty close match to the brake calipers (Compass Yellow?)
Rivian R1T R1S Color-Matched Vinyl 20221209_195432932_iOS
Also, VVivid Ultra Gloss Candy Charcoal Grey is a close match to the grey paint on the 21" wheels (maybe 20" to but I can't confirm). I was working on a project and thought to myself that it looked really close to the factory wheel color. There is a lot of flake in the vinyl so depending on the angle it does change a bit. It is a really thick vinyl that has a protective layer to keep it from scratching, but I had to set a Cricut to "light cardstock" to actually cut through the vinyl, and leave the backing. Could be used to cover the machined portion of the wheel if you want a single color look, or maybe cover a generic center cap to match if you don't have the caps from the Gear Shop.
Rivian R1T R1S Color-Matched Vinyl 20221209_195641791_iOS
Rivian R1T R1S Color-Matched Vinyl 20221209_195646837_iOS
Rivian R1T R1S Color-Matched Vinyl 20221209_195710650_iOS
Rivian R1T R1S Color-Matched Vinyl 20221209_195715157_iOS
If you find vinyl that matches any of the factory colors please post here so we can keep a database.
