HVAC fan low hum normal? (video)
AZTes2Riv
Alex
2024 R1T Dual Motor Performance
Law Enforcement
Disclaimer: I totally understand Rivian HVAC is a NVH mess, as is well documented. Asking apart from the general AC loudness.
For the last couple months a low hum has developed whenever the AC fan is on, at any speed. It is not the compressor, as it happens with fan on and if AC (compressor) is off. Hum increases with fan speed and goes away when fan is off, and audible at all fan speeds. Almost sounds like the blower wheel is tilted or hitting something. I’ve looked at the fan where it’s visible behind the fresh air filter, don’t see anything outside the norm. The sound seems to be coming from behind the fan itself.
Looking to see if this constant buzz/hum is normal in all R1’s or not. Video attached. Thanks all!
Not seeing a video if you had attached one, but what you describe sounds abnormal to me.
AZTes2Riv
Alex
Law Enforcement
Tried
tried to upload it 10x, fails every time, sorry
No worries. It can't hurt to submit a service request. The worst that can happen is they check it and tell you it's "within spec".
