L2 charger down to 2.7kwh at 24F.. Should I be worried?
MarkNorman
Yakima, WA
‘22 R1T QM, ‘25 R1S DM L, ‘24 Tesla Model 3 DM
L2 charged from 60% to 85% after the 51.31 hot fix OTA. Previously, starting from 20-30F, the pack would warm and hold a steady 46F during L2 charging. Only difference I noticed after the update was the pack temp got up to 48F, which is SOO CLOSE to the Gen 2 50F L2 throttling threshold its maddening. Maybe if I let it go past 85% it would have got there. More testing…
SparkyR1t
Chicago
R1t/Model Y
Retired Commercial Electrician and mechanic
Agree not normal. Give Tesla charging support a call at 877-961-7652. If your Tesla wall connector is connected to WiFi they can assist with a fix. Had to do this with my R1t initially. Really helpful group
portdirect
Missouri
Blinkenlight Hearder
This is nothing to do with tesla chargers, Rivian are quietly via unofficial channels admitting there’s an issue (it’s impacting employees as well) - but they also may never be able to fully resolve these issues via software alone on the gen2 max packs. hopefully that’s proved wrong and they find a way; my suspicion right now is that they can’t both power the battery heating system sufficiently and l2 charge simultaneously. This speculation comes from @MarkNorman ’s observations on dc charging preconditioning to mitigate the issue, I’m struggling to think of another reason they wouldn’t just run the heater whist charging: like they do on the gen1 models… if so I wonder if they will end up doing somthing like cycling between periods of l2 charging and battery heating in low weather; would be weird, but would cut the overall charge time.
MarkNorman
Yakima, WA
…if so I wonder if they will end up doing somthing like cycling between periods of l2 charging and battery heating in low weather; would be weird, but would cut the overall charge time.
I’ll bet it is pulling some power for heating the pack, there is a 0.5 to 1.5 Kw delta between the consumption reported by the app and the charge rate reported by ABRP.
I greatly dislike that my 2025, $90K R1S L2 charges worse than my 2013, $4K Nissan Leaf, but it seems like we’re making some progress with each update. I think they’ve got it to a place where I can top charge when I need to (even in the cold) and it will reach 100% in a reasonable amount of time.
Back in December, when the pack was <50F and >90% SoC, it’d L2 charge at <1kw and give me an estimated completion time of like 36 hrs. Definitely better than that now, but still pretty bad.
mkhuffman
2025 R1T Tri-Max, Jeep GC-L, VW Jetta, Kia POS
When did the L2 charging speed start to throttle? 80%? Higher? How much throttling did you see this time? Any throttling is unacceptable, IMO. But if starts later, and isn't as severe, it might be livable. Maybe.
MarkNorman
Yakima, WA
I didn’t take a screen shot this time, but it definitely started throttling at <80%. I’ll do a better job tracking next time and charge above 90% to see where the stair steps are now.
portdirect
Missouri
this is why I’m starting to think it could be about being able to put sufficient heat where it’s required. in gen1 there was simple resistive heater in the pack afaik, whist in gen2 I think they have a heating element inline with the heat pump? All speculation of course, as these trucks are wonderfully opaque
MarkNorman
Yakima, WA
Gave 2024.51.31 another try this afternoon and didn’t see much, if any difference. In the screenshot you can see the classic Gen 2 cold-pack, high-SoC, stair-step L2 throttle. The amperage offset from 2024.51.30 does make a slight difference by bringing up the throttled rate by about 1 Kw.
My hope that 51.31 would bring up the pack temp does not seem to be born out since it didn’t get above 46F.
I sure hope Rivian got a screaming deal from the Gen 2 NMC cell provider because they suck!!! Boohoo for me, I know. I’ll live.
Rivian R1T R1S L2 charger down to 2.7kwh at 24F.. Should I be worried? IMG_9235
MrMechanic
Luke
Iowa
2025 R1S Gen2
Tried charging from <60% to 100% soc last night after hot fix 51.31 was installed a couple days ago (large pack). Looks like I'm at 0.7kw instead of 0.5kw when over 90% soc. A little improvement but nothing like we should have. Battery was 44°F this morning when I unplugged after the screenshot so the charging didn't add heat to the battery (garage was at 44°F as well).
Rivian R1T R1S L2 charger down to 2.7kwh at 24F.. Should I be worried? 1000016091
SeaGeo
Brice
Xc60 T8
It's the same cell as the Gen1 max pack.
(I don't love the cell either).
MarkNorman
Yakima, WA
Interesting, so do you think it’s just the switch to the heat pump that’s causing the L2 throttling issue at lower temps and high SoC or is there another variable in this equation?
MrMechanic
Luke
Iowa
2025 R1S Gen2
Replugged the car in, now charging at 1.2kw instead of 0.7kw. Battery is still same temp (43 to 44°F) at 97% soc.
Rivian R1T R1S L2 charger down to 2.7kwh at 24F.. Should I be worried? 1000016098
SeaGeo
Brice
Xc60 T8
I don't whyot would be the heat pump
Honestly, I don't understand why there is an issue all. Hope it's just a bug.
