Navigation continues to be wrong
eRacer
Napa, CA
Wanted to bump this up as the current update didn't fix the issue with the navigation. The destination is still called out on the wrong side of the road.
Mellowyellow
C'mon Rivian, just pay the money and get us native Google Maps!
VSG
R1T LE/RB/OC/20
This is your first post in this thread. What destination are you talking about? Did you report the issue (see above)?
And why would you expect that a vehicle software update fixes a mapping data issue?
If you report issues like this, the mapping data gets fixed. I have done it twice now, and both times it got corrected within days in Mapbox. It can take a week or so after that for the changes to start showing up in the vehicle.
eRacer
Napa, CA
I don't understand why my "first post" on this thread has any relavance to me brining up an issue that another member as aslready. (Posts #3, 5 and 8 in this thread.)
The issue I am pointing out is not specific to a location but as to how the desination is called out on the incorrect side of the road for EVERY location. It's not an error with the MAP. However an error in the guidance system.
This error only came up after the previous update. Hence why I thought that the error would have been corrected with this current update.
Are you recommending that I report EVERY location that I direct my navigation to be on the wrong side of the street?
VSG
R1T LE/RB/OC/20
It's totally relevant because your post said "The destination is still called out on the wrong side of the road ". That references a problem from the past that hasn't been fixed yet, but you never posted about that past problem. You provided no context about what destination was or what you have done about the problem. And you said nothing about when and what you did to try to correct that, and whether you even read or followed the advice given by previous posters.
VSG
R1T LE/RB/OC/20
See, once you start adding details, it's a different story ...
No, it is not true that EVERY location is on the wrong side of the road. Not even close to true. And nobody in this thread has said that.
Again, new information - no one else has said this is something that only started occurring on a previous update. Did you expect us all to know the details of your particular problem when you never posted those details before? You bumped this issue because the problem was "still" happening, but the OP has a different problem than you and you never explained your problem.
And if you truly believe that EVERY destination is wrong and that this is a navigation issue, have you reported it? No? If Rivian doesn't know about it, they can't fix it, and again why would you expect something to be magically fixed if it hasn't been reported and if no one else is saying they have that same problem with EVERY destination?
