beatle
- Joined
- Jun 20, 2024
- Threads
- 14
- Messages
- 666
- Reaction score
- 849
- Location
- Springfield, VA
- Vehicles
- '23 R1T PDM Max, '97 Miata, '19 Monkey
- Occupation
- IT
- Thread starter
- #1
With the other threads related to slower charging at higher temps, I've been using ElectraFi to monitor my charges to see if it's affecting me as well. My charging power remains flat at 9.3kw (240v, 40A) but after a few hours of charging, I notice my charging "speed" in mph dips for about 10 minutes. It goes from 23 mph down to 16 mph. This recurs about once every hour until charging completes at 85%.
My only guess is that the battery is balancing itself and bleeding off excess capacity from higher cells after the pack reaches ~50% SoC. It seems a bit wasteful to balance at a low SoC to balance, but maybe they're just being super cautious? Or maybe it's not balancing at all? Since the charger power does not drop, I don't believe this is throttling due to a warm plug or other fault. The truck just decides to use its power for something else for 10 minutes and it doesn't go directly into the battery so the charging "speed" is temporarily reduced. I could probably observe a lower speed if I were to run the cabin AC or heat at the same time. Here are a couple screen shots:
When I charged last night from 62-85%, the dips appeared aft]er only an hour or so, perhaps because the truck was already above 50% (note the time scale is different here due to the shorter charge session):
I don't think anything is wrong, but it's interesting to see and I wonder what is actually happening.
