Possible DIY for road noise reduction (Gen 1)
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
Quick video of a few DYI steps to help reduce road noise in the Gen 1 vehicles.
I've personally never been bothered by it but I know others bring it up as a point of contention and it may really come down to which tires you have on it. The 20's AT are much noisier than the 22s that I have.
First I do a window reset at each window to ensure tight closure. Then I installed a small amount of weather stripping around each window and the windshield.
Seems help a little, but again I wasn't bothered by the noise.
Ecupip
NC
Rivian, Audi, and 2 Jeeps
I'm fortunate to have the Meridan system, so road noise, or any noise other than what I chose, is nonexistent. :rock:
Dynamat is likely going to be your best bet to help reduce road noise.
narmstrong79
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
This is what I’ve done which helped with the wind noise not the road noise. I plan to do more of it and have a couple more rolls of the material.
Yes - I installed in that same channel. Its not a huge difference, but once the HVAC is running and music is on i never notice road noise. I may try that inside the door location too! thanks for the idea.
narmstrong79
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Depending on the location you may want to use open or solid. In the case of doors and window channels where you just want increased pressure, I'd go with open. I tried solid in the window and it was not good. However for spaces like the roof channels either is fine.
Also note that silicone and EPDM are vastly different materials, and I prefer the silicone results. It should also handle UV/weather better.
Birdowin
Portland OR
Rivian R1T / Tesla model S
Retired from construction.
What diameter is the foam that you used?
narmstrong79
narmstrong79
Nick
New Hampshire
www.youtube.com
Marketing
Rally1
Long Beach
R1S, VS30, LR4, LR3
For me, the passenger window suddenly doesn't close all the way. It came back from the SC like that, despite no work related to that being done…
Now waiting on a mobile appointment as any attempts at self calibration have not worked.
Rally1
Long Beach
R1S, VS30, LR4, LR3
This video helped me close the gap, the half pull seems to be the difference maker.
