Where can I get that Lightbar wrap with the Rivian cut out?!Needed to pass some wires from the bumper to the inside of the frunk. Removal is pretty straightforward.
-Remove the four plastic covers surrounding the frunk. The front piece is magnetic and the others have simple clips, just gently nudge them upwards and they release pretty easily.
-Remove the 6 screws (circled red). 2 up front, 2 in the rear, and one on each side.
-Unclip the two plugs on each side (circled red)
-Lift out the tub and enjoy the brilliant engineering
bulkheadSee any available grommets on the fire wall (can I call it that now?) for good pass through?
No need to be so rude, it was a simple question.bulkhead
Sorry I’m old and my hardware can’t run the new software.bulkhead
water should not be a concern most of those bits are blow 42" which is the fording depth and can be completely submerged.Random question. Does the frunk drain plug continue through a drain line underneath or just empty right into that space? When I did the a ride along in a test drive, I mentioned a plan to have a few beverages on ice in the frunk to surprise some friends when I get my truck. The rep told me they do not recommend ever using the frunk for that purpose, but wouldn't elaborate why. She said the drain plug was only for condensation. She also said of course it would be my truck so I could do whatever I want with it, lol. My reply was that since I have to wait another year for a max pack, by then there should be plenty of Youtube examples of the successes or disasters that result from using the frunk as a party cooler. Based on your view of what's underneath, would draining water from it be a concern?
(And yes I know the spare tire space can be used for this, but my beverage supply plan will involve off road locations where I wouldn't go without a spare)
I remember the guide saying the same thing about a drain plug. I wasn't really paying attention to this when I pulled it out, but I don't remember seeing a specific drainage site nor was there a tube at the bottom of the tub to drain out of. So based on the amount of electronics in there I would not want to dump water down there.Random question. Does the frunk drain plug continue through a drain line underneath or just empty right into that space? When I did the a ride along in a test drive, I mentioned a plan to have a few beverages on ice in the frunk to surprise some friends when I get my truck. The rep told me they do not recommend ever using the frunk for that purpose, but wouldn't elaborate why. She said the drain plug was only for condensation. She also said of course it would be my truck so I could do whatever I want with it, lol. My reply was that since I have to wait another year for a max pack, by then there should be plenty of Youtube examples of the successes or disasters that result from using the frunk as a party cooler. Based on your view of what's underneath, would draining water from it be a concern?
I have no doubt one of those will be waiting for all of us after warranty is over.what ya got there is a standard Johnson Rod
The charge port door.In the bottom of the middle picture is what looks like an emergency latch release. But since you need to get INTO the frunk to remove stuff to access it, it seems unlikely that it releases the frunk latch. But what else could it be a release for? Is it accessible through the grill (which means it could release the frunk)?
