I'm waiting for a company to release an EV pickup with a front bed. Or a fred
Of course, it would also have a frailgate.
If Rivian makes a vehicle with a front gear tunnel, can we call it the fear tunnel instead of frear tunnel? Frear is just too confusing.
Joel
Joel
Florida
Volvo
I see the 12v battery under the cowl. And who said BEV’s were simpler than an ICE vehicle?
I think it has been reported that the 12v battery is actually 2 6v batteries.
lostpacket
Vermont
Crosstrek, R1T
I think you just invented the frunnel!
OverZealous
Louisville, Kentucky
Jac
Jacob
Connecticut
Rivian R1S, Volvo XC40, Honda VFR1200X
Might not be too attractive from the front and likely problematic aerodynamics, but imagine a design with a front cargo rack which would be called a “frack.”
mini2nut
Rivian R1T, Model Y
I believe you are correct after zooming in on the photo. Interesting…
Rivian R1T R1S Removal of frunk tub (front trunk): DIY how-to & pics 1649855641656
Robotpedlr
2023 Rivan R1S
Laser shifters. With 835hp its hard for me to maintain proper speed.
Thanks.. very helpful. I will also be installing AL Priority Shifters (assume that is what you are doing). Once everything was removed per your info above, was there any easy to access points to pass the wires through the firewall into the cabin? Just did this on my new 22 Tesla Model S and it was a huge PITA.
OverZealous
The tow guide explicitly refers to them as two 12V batteries, I think they are just small batteries.
My Tesla has a single, similarly small 12V battery. It's proven to be underpowered for the vehicle, so they swapped it with a fancier battery that fit in the same spot (some nano-tech carbon battery). I'm guessing Rivian figured it was cheaper to have 2 small 12V batteries than make room for a larger one or have an expensive battery.
Rivian R1T R1S Removal of frunk tub (front trunk): DIY how-to & pics Screen Shot 2022-04-13 at 9.56.28 AM
mini2nut
Rivian R1T, Model Y
Thanks for the information.
I think a small 12v lithium battery would fit perfectly under the cowl and help eliminate some wiring. I know the refreshed Model S now uses one. It's probably the higher cost that prevents Rivian from installing one at the factory.
crashmtb
Man oh Manitoba
I think a small 12v lithium battery would fit perfectly and help eliminate some wiring. I know the refreshed Model S now has one. It's probably higher costs that prevents Rivian from installing one at the factory.
Lithium batteries also require more care and feeding than a lead acid/AGM one…in addition to being more expensive
Trandall
Travis
Upstate NY
Rivian R1T, 2023 Mach-E
Construction Management
This. I think they are two small 12V in parallel. I doubt they would source 2 6V in series for a variety of reasons.
CommodoreAmiga
INACTIVE
INACTIVE
I'd be curious to see under the covers and get actual specs on the batteries. At least a voltmeter could quickly/easily confirm.
Maybe they're 6V batteries.
Maybe they're 12V "powersports" batteries.
It'd be kind of nice if they're powersports batteries, so at least replacements are likely to be found in stock, locally.
the long way downunder
charging
Tesla
WFH
To my eyes, that's a helluva lot simpler than an emissions-compliant engine built in the last 25 years … : )
