Tesla Universal Wall Connector - has yours frozen?
beatle
Springfield, VA
'23 R1T PDM Max, '97 Miata, '19 Monkey
I've been a fan of the Tesla UWC since I installed them in July. I have one in my garage and one on the outside. The built in J1772 connector on the outside unit recently froze in the housing since we've had snow and a lot of sub-freezing temperatures over the past couple weeks. I was still able to pull the NACS wand out and use a standalone J1772 adapter to charge, but the button on the built-in adapter would not release the assembled connector from the housing. I pulled the NACS wand out and took a battery powered heat gun to apply heat to the built-in adapter for about 10-15 seconds, then reinserted the wand. With a little jostling, the assembled connector came free. I noticed a thin layer of ice had built up around the adapter.
I did a little searching and some people have had similar issues over on the Tesla Motors Club forum, so I guess this is something to be aware of. Seems like a design flaw for units mounted outside. If you already carry a NACS>>J1772 adapter you can be prepared to still charge if you don't have a heat gun handy, but if you experience the same issue, this is one thing to try before calling Tesla.
Mellowyellow
Westchester NY
This just happened to me last night for the first time ever! All I did was put my mouth over the opening like I was going to make out with it and breathe out of my mouth for about 5 breathes and the adapter came out. Probably it just wanted me to stop assaulting it with my mouth and bad breathe
