Water Sloshing
benjiak47
Ben
Charlotte
Tacoma, with an R1T ordered.
After it rains heavily, I hear water slashing around inside the vehicle. Does anyone know how to get it to drain, and where it is accumulating?
Kitsap, WA
Put a ticket in, sounds like your door seals were put on backwards, known issue. They're at the bottom of the doors and are long skinny pieces, research on the forum about it. I'm sure it's DIY but better to have pros do it in case they break. Ever since mine were fixed, it no longer sounds like I'm underway making way after a car wash, for better or worse.
bael
GA
LE R1T, X5
This is the way
when first discovered, they would also drill them out.
Known issues and easy fix for the SC
code3Riv
steve
norcal
I have the same issue. Not in the doors but under the drivers side seat area. Noticeable sloshing upon acceleration and deceleration. Took it to the service center. They checked the door panels, drain plugs and found nothing. They ran water over the R1T to try to simulate rain. Just rained last night and same problem. It will drain out slowly if I park on an incline.
