What Cargo Basket/Trays are People Using Over the Bed?
camaroz1985
Carlisle, PA
R1T, ID.4
I am looking at getting a cargo basket to use for some upcoming trips that I would like to mount on the cargo bars over the bed. I have seen the Yakima MegaWarrior and an Amazon aluminum basket being used. It looks like from the window to the rearmost part of the tailgate it would be 67-68", and from the edge of one bed rail to the other is about 55". I would like to keep within that envelope.
I need a minimum of 60" usable length, and as wide as possible to maximize the space. I was leaning MegaWarrior with a cut down extension (only if I could find it used, because I'm not crazy enough to cut up a $250 extension just to get an extra 6-16 inches), but would like to know if there is anything I am overlooking.
I did also find a cheaper 64"x50" basket on Amazon. It seems that with a little extra prep (spraying it with Herculiner and replacing bolts with stainless) people are having good luck with it.
https://www.amazon.com/dp/B08B87HDF2/
Let me know what you are using and how it is holding up for you.
Rexbo
I fit this up today for offroading, since I found it on CL for $20 and it works for me. It's a Thule something.
If youre really picky, consider just buying a bunch of 8020/t-track and fabricating it.
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? PXL_20230108_000853447
C.R. Rivian
Charles
South Puget Sound
Thule Sidekick Model number 682100, fits perfectly:
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? 1673159711584
Damn, that's a good looking truck...
Frank65
Frank
Omaha
I have that Amazon rack. Holding up good. I painted the welds for extra corrosion protection.
How did you get the wing nuts on the u bolt on the mounts?? The u bolts are too short for me to get enough clearance through the plate
KyleJJ06
2022 Blue R1T
Harbor freight rack. Can’t remember the dimensions, but might not be big enough for you. Ill get another one when it rusts out too much for a coat of rustoleum to hide.
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? IMG_2004
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
Yakima skinny Warrior. I was able to find a used, like new, one on Amazon for a bit of a discount.
OffRoad987
Henry
Southern California
Rivian R1T , Porsche Cayman
I didnt use plates on one side.
Wasnt an issue, except for height difference. U can install without the plates.
I put on a Xtrusion Rack now. That cheap amazon rack was getting rusty.
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? IMG_3991
camaroz1985
camaroz1985
Carlisle, PA
R1T, ID.4
I forgot I started this. I ended up skipping a basket, and got the Yakima LockNLoad Platform B instead. I found one for less than half price, brand new, so it was hard to turn down.
Worked perfectly on a couple trips, even if it was a bit reminiscent of the Beverly Hillbillies.
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? 20230623_031333947_iOS
This one was a little better.
Rivian R1T R1S What Cargo Basket/Trays are People Using Over the Bed? 20230630_190608555_iOS
Reactions: Woo
RivSam19
sam
Philly
M3
Hey, how is it holding up? I'm looking into getting one and for $85 it's hard to justify getting something else 4x the price.
LNL_HUTZ
Gene
San Francisco
2024 R1T Quad; Tesla MYP
Has anyone found a basket that has T-slot mounts for attaching to the Rivian crossbars? Instead of the U-bolt types?
