British Columbia Rivian Owners
Owners of R1T or R1S models in British Columbia Canada
Share this group
Quick Overview
Category
RIVIAN CLUBS / GROUPS
Language
English (US)
Total members
Total events
Total views
6,028
I apologize if this is not the appropriate place to post, but I installed the running board and wanted to share some of its features here.
Features
Perfectly Fit:
Enhance your Rivian R1T/R1S fully customized running boards. Designed to perfectly fit the Rivian R1T/R1S 2022 and 2023 2024 2025 models, the width of the pedal is 17.5 cm, making it easy for people to step on and off the vehicle.
Durable and Safe: Made from high-carbon steel with an anti-slip design providing additional safety, delivering superior strength and wear resistance compared to conventional running boards. It has minimal impact on ground clearance and reduces the risk of damage when driving over rough terrain.
High-strength bearing capacity: Hansshow Rivian running boards are engineered to provide hassle-free access to your vehicle while maintaining superior strength and stability. With a maximum weight capacity of 400 kg, these steps are designed to securely support you and your passengers.
Easy DIY installation: Installation is straightforward, bolt-on design, and DIY friendly. No extra parts or specialty tools are required. No permanent modifications to the truck frame structure are required
You can use my discount coupon to purchase a standard or power running board here if you are interested. This coupon code offers 25% off. This is a Black Friday deal; it will end on December 1st, after which you will only receive your regular discount. RIVIAN is the discount code. https://www.hautopart.com/collections/rivian-r1t-r1s
Show full message
