Wisconsin Rivian Club
Wisconsin Rivian owners and enthusiasts community
Share this group
Quick Overview
Category
RIVIAN CLUBS / GROUPS
Language
English (US)
Total members
72
Total events
Total views
13,998
I'm planning an upcoming drive from MKE to St. Louis. Has anyone does this drive? Any suggestions on charging stops?
Show full message
bd5400
bd5400
I haven’t taken the entire trip, but I was able to easily make it to the EA charger in Normal, IL, which is on the way to St. Louis. That was in September, however. If the weather is frigid you might want to plan a stop in Rockford just to be safe.
Citrinite
Thank you. It sounds like the EA in Normal worked well?
Craigins
Craigins
use plugshare to check the status the day before and the day of the trip just to make sure all stations are up and running. I've made the trip from Chicago burbs down to St. Louis. There isn't much in terms of charging in central IL, I did have to wait about 15 min at the Walmart EA station to charge.
Citrinite
The drive went smoothly. Only had one issue with one station where it derated due to plug temp. However that was on a 150 kw unit when all the 350s where occupied. The truck could have made it from MKE to STL with one stop from 100% charge (in Bloomington) but we opted for a second short break/charge. That said it wasn't that cold outside (in the 40s).
