DCE
Anaheim California
www.weistec.com
Rivian R1T & R1S
Hey everyone! Excited to share our newly released Front Skid Plate designed specifically for the Rivian R1T and R1S.
This upgrade replaces the factory plastic skid plate with a far more durable solution, offering real protection where it matters most. Whether you're tackling rocky trails, crawling over obstacles, or blasting through sand, our skid plate is built to take the hit—so your underbody doesn’t have to.
đź”§ Key Features:
  • Precision fit for R1T & R1S
  • 25lbs
  • Replaces factory plastic skid plate
  • Made from 1/4-inch 5052-H32 aluminum — lightweight, strong, and corrosion-resistant
  • Rugged textured black powder coat for added durability and a clean, aggressive look
  • Fully bolt-on installation — no cutting, drilling, or welding required
Designed and manufactured in-house right here in the USA 🇺🇸.
If you’re looking to add some serious protection before your next off-road trip, this is a must-have.
Feel free to ask any questions — happy to help!
👉 Check it out here: Front Skid Plate
Rivian R1T R1S New Front Skid Plate for Rivian R1T & R1S by DCE Weistec 9
Rivian R1T R1S New Front Skid Plate for Rivian R1T & R1S by DCE Weistec 11
DayTripping
Timothy
DFW
DuncIT
Duncan
Radnor, PA
25 R1T, 25 Polestar 3, 18 Model 3, 90 MX5, 51 Hudson Pacemaker
Curious what it weighs?
DCE
DCE
Anaheim California
www.weistec.com
Rivian R1T & R1S
@DCE Are these self-install or do you need to go to SoCal?
Self install! Set the vehicle on the highest setting and you're good to go! No cutting or fabricating needed.
DuncIT
Duncan
Radnor, PA
Does this use the existing mounting fittings? If so, and the original piece is plastic, can they support the weight?
DayTripping
Timothy
DFW
I am torn between the 2. The Weistec is $50 cheaper and I like the looks of it other than I'd prefer just an aluminum finish so when it gets scratched it won't show as badly.
I don't really want to add a bunch of unnecessary weight but they are both about the same weight so I'd look at which is probably stronger. At the same time, I am sort of an impulse buyer so whoever had a sale would probably be the one to pry the money from my wallet first. ;)
Sgt Beavis
Rick
Overpaid Computer Nerd
I definitely prefer the cleaner look of this over the Rival skidplate.
DayTripping
Timothy
DFW
Me too and easier to clean. If they offer plain aluminum option it would be clearly my first choice. Under car clean airflow is important too. At the same time, does the "venting" on the Rival actual help keep anything cooler?
csharp
NC
2023R1T, 2024 R1S, Suburban
If it helps your impulse buying... the Rival is out of stock currently.
EV Sportline
evsportline.com
Upgrading Electric Vehicles
We have the Rival in-stock, plenty of them ready to roll! :rock:
Reactions: DCE
DCE
DCE
Anaheim California
www.weistec.com
Rivian R1T & R1S
Yes, the skid plate utilizes the factory mounting points. While the OEM piece is plastic, the vehicle’s mounting locations themselves are robust. The strength comes from the distribution of force across multiple mounting points, not from any single bolt. When installed, the combined support of all the fasteners ensures the plate can handle impacts and stresses from off-road use without issue. It's designed to take a hit while keeping your underbody protected. In a situation were you'd bottoming out the front on steep angle, the front lip (bumper) of the vehicle would hit first before reaching the skid plate.
Let us know if you have any other questions!
