Ac/heat/fan buttons
Billofaustin2
Bill
Austin
R1t
I’m sure this has been mentioned but to put it out there again. 1 month into my R1t. I would like to see a separate button for “cold ” “heat” and “fan only”
many times if the temp isn’t correct I cant select the correct setting. I have to reduce the temp then select cold for example. Also there is a delay on the button as you cycle through the options. The ac screen has plenty of extra space to break these out.
Thanks.
