Bug or Design Intent
ERguy
Midwest
F150
The purpose of the sensor isn't just to read 65lbs but something smaller that shouldn't be there but is. I have a 2020 vehicle that anything close to 25lbs sets it off. Should 1lb set it off, now but anything that could be a small child should set it off.
They are designed to know the difference between a person and any inanimate object that weighs 25 lbs as in your example. Nobody wants an airbag deploying on a 25 lbs sack of potatoes. Based on the OP, it sounds like Rivian cannot tell the difference right now as evidenced by the truck telling the OP to fasten the passenger seatbelt.
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
Someone should contact VW (I believe they are the largest vehicle manufacturer globally) their sensor does it by weight not determining if it is a human or not.
lostpacket
Vermont
Crosstrek, R1T
4) Very annoying that the Gear Guard screen presents itself everytime you get in the truck. Also, have to reboot the truck occasionally to get the gear guard to work again.
How could you not want this dashing gentleman to greet you when you enter your truck?
Clearly you don't possess my superior cultural sophistication
Rivian R1T R1S Bug or Design Intent 1650935393483
