Front Radiator Louvers Creaking
elektrode
Bran
NC
Honda Ridgeline to R1T
Well this doesn’t sound normal or good
Anyone else hear this after a cold wake?
BillyBob
Bill
Kirkland, WA
Traverse
Just retired
Sounds like a scene from the Boris Karlof movie, "The Return of the Vampire ..."
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
I am 70% sure that the answer is dry lube.
atebit
R1T, Porsche Boxster
I had this problem corrected on my truck by the Brooklyn SC. They told me there was some rubber tubing that the louvers were rubbing against, which they re-routed. I haven’t had the problem since.
When I opened my case I did use the “vampire’s coffin” analogy in the description . The Service Manager in Brooklyn said that got some laughs when the techs watched the video I included. :)
CKlawyerWV
Caleb
Charleston, WV
'22 Rivian R1T, '01 Jeep Wrangler Sahara
My R1T (delivered Saturday) has this issue too. I'm going to create a service ticket for it if it persists for a couple days.
whyasky
Yury
Mid-Atlantic
R1T, ID.4
I'm having this issue. Dry lube applied. Will report back on results.
Edit: I was very happy to see this post. Thought this might be a suspension noise!
elektrode
elektrode
Bran
NC
My current guess is there are some nylon bushings causing the issue. Unintuitively, nylon expands under colder temperatures. I think as we are entering autumn, that’s why it’s starting to pop up now.
edit: this might be a crappy hypothesis. I recall reading about this nylon property on the internet, but I could not find a good reference today for it. Plus it’s pretty hot here today and it’s creaking anyway.
kithjin
Jim
Portland, OR
2023 R1T adventure package
Engineering Manager
i also had this problem. I walked into my closed garage with my cell phone to get something in the freezer. The truck woke up and groaned. It was so loud it startled me. I thought my garage door spring was about to break :).
I originally thought it was the suspension too until I saw the louver moving.
I took it into service and they lubed it. the service rep said this is a common problem. I haven't heard it since.
Had this noise, applied dry lube at each point where the louvers entered the side plastic and I no longer have the noise.
JGard18
Acton MA
I had this. Sprayed dry lube on both sides of the vents and the noise hasn't returned in months.
