How do I delete a Rivian charger from an account?
caprifolia
Martye
RS
Long story short: took delivery yesterday. Delivery person said I needed to make a new Rivian account and couldn't use the one I had previously created to pair with the charger. Now I can't pair with the charger on the new account until I delete it from the prior account. I can't find where to delete it.
Select the wall charger from the vehicle and gear screen of the app. Scroll to the bottom and you’ll see the option for delete from account.
SFsoundguy
Bay Area
Rivian R1S, Lucid Air Touring
Also if you had already paired the charger with your phone you will need to delete the bluetooth setting that was set up its "Wall Charger 00..." just select that and forget this device then when you setup the new charger bluetooth will reestablish a new connection.
caprifolia
Martye
RS
Thanks for the reply. Deleting the bluetooth connection on the phone was not sufficient. The charger needed to be deleted from the Rivian account which I finally figured out how to do.
