Location-Based Garage door button not showing up any longer.
R1SS
Ryan
Oceanside, CA
2023 Rivian R1S
3D Animator
Anybody else had this happen? Normally when I get close to home or leave home, the garage door button prompt would show up.
A couple weeks ago it just stopped working.
wondering if I need to fix a setting in the UI that might have been disabled?
Trufflehunter
Georgia
Did you turn off proximity when you are at your home location? This will disable the steering wheel garage door opening prompt.
CharonPDX
Charon
Cascadia
InfoSec Geek
yep, there have been a few threads on it - disable and re-enable, and it will come back.
jrange
Jamie
Dallas
R1s
Cyber
Tried this and mine is still not back. Waiting for the update still, up that will correct.
R1SS
R1SS
Ryan
Oceanside, CA
2023 Rivian R1S
3D Animator
I disabled it, re-enabled it... and also did the new update and it's all working again.
RivAW
Alex
MA
This is not correct. I always have proximity “off at home” and have no issue with the garage shortcut. They two are completely unrelated
RivAW
Alex
MA
Disable then reenable the shortcut in garage settings . It should resolve. Worst case, full reset …happens once in awhile.::
CANCERDOC
Southern California
2024 R1S PDM
Healthcare
Mine still pops up when I drive up tot he house. But one annoying thing after the update is that the garage door control disappears while I'm backing out of the garage. Sometimes it will come back so I can close the door once I've cleared the "doorway" but other times I need to click the garage icon to manually bring up the menu to close the door. Doesn't happen when I roll up to the house. I wonder if it has to do with the car losing the home wifi while backing out of the garage.
GRC
GC
GTA Ontario
2024 R1S
still figuring it out
I had the original issue after the update (with the garage icon not displaying) and did the disable and renable and it fixed it. This was a few weeks ago...now as of a couple days ago something strange happens ...as I am driving I see occasionaly the garage icon popping up (the way it should behave as I am pulling up home) and it is annoying since it comes up and stays on....to make it worse, now as I approach my home it doesn't show up (as it should) - Going to disable and reenable today to see if that fixes it...but wanted to see if anyone has this issue?
rivian_enthusiast
Same issue for me after last night release. Location also changed to a road couple of streets away. Anyone knows how to get it back and fix the location?
omsatt
Lexus GX470, Lexus ES350
Physician
Same issue for me. I've done the infotainment reset a few times and the full reset. Nothing has resolved the issue. Very annoying.
