Navigation volume control setting?
omsatt
Lexus GX470, Lexus ES350
Physician
After the recent update I can no longer find the control for navigation volume. The chime is way too loud and I'd like to turn it down. Previously when you hit the gear icon it'd have an option there for navigation settings.
Did this move to some other menu?
Thanks for any help you guys can offer.
It is under volume settings. Click the speaker on the bar, then click the source at the top to see all settings you can adjust. You can also use the volume wheel on the steering wheel while the navigation is speaking.
omsatt
Physician
Awesome! Thank you very much!
I used to access the nav volume via the gear icon that you can see above the the electric bolt. It used to be that you clicked that and navigation volume would show up. Now, however, if you're actually using the navigation you cannot change the volume. You'll have to end the trip, click that icon, then change the volume. Which is dumb.
But thank you for your help, I learned something.
shandel
Half Moon Bay, CA
R1S FG/FE Adventure 20, Audi e-tron, Jeep Wrangler
You can also click the left wheel on the steering wheel up or down right after the navigation speaks or chimes. It is in navigation audio mode for a second or two and if you change the volume it changes it just for the navigation prompts if you do it then.
omsatt
Physician
Thanks!
DKM_R1S
Dan
West Chicago Suburbs
Manufacturing
Thanks for the tip! I would have never figured that out. I never use that volume control, on the right side of the screen. Only my wife does.
