New UI Requested Changes
goldburger
Suspension selection: Soft > Moderate > Firm (right now it strangely goes Soft > Firm > Moderate).
No it doesn’t.
Tapping the fan speed should turn on the HVAC, if it is off. Right now you have to use the power button icon.
That’s how it used to be and agreed it should be like this.
If no one is in the pasenger seat, the right temp control should be replaced with a fan speed selector.
Turn on Sync.
Surferdude
Hawaii
Tesla
There needs to be a fan speed selector fixed on the screen next to the temp selector. Nobody should be diving into a menu to change fan speed. And yes agree with OP that the fan speed selector should be able to turn on and off the AC. Adding a power button is redundant and just requires more menu diving. Very poorly designed as is.
Also the AC/comfort settings shouldn't reset when you leave the vehicle. Right now I'm constantly pressing the ventilated seats button every time I start the vehicle because Rivian keeps turning it off for some unknown reason. Same goes for rear AC control. Turns off every time forcing deep menu diving to get it back the way I had it when I left the vehicle. Leave the comfort settings alone.
Glembi2
Vienna, Virginia
R1S, Genesis GV70, Civic
Patent attorney
I get turning off the HVAC requires two taps (the tap to pull up the HVAC screen and the power button to turn it off) but I’ve been using the one touch approach to turn it on. From I think any screen, increase or decrease the temp and the HVAC turns on to Auto.
For those of us with OCD (not naming names), yes the temp is one higher or lower than where one left it but the change in UI is much less abrupt (one up + one down with no screen changes). And for those of us who require the HVAC be only set to prime numbers, I’m going to stop here.
Joefly78
Joe
Atlanta, GA
2023 R1T Max
Pilot
Minuscule thing that is meaningless and nonetheless driving me mad...the new grey oval background behind the temperature is misaligned vertically on the drivers side. The grey oval is too high. Passenger side looks right.
