Problem with Tesla Universal Wall Connector
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
I will. That said, I am going out of town for a few weeks so my response will be delayed. Stay tuned.​
solaskaze
Los Gatos
Tesla X,3, R1T Duo Max
I have no problem with a UWC and Gen3, Gen 1 Rivian.... other than the standard "panic" that happens for a few seconds until a connection is made.
It could be your firmware in the connectors. When is the last time you upgraded them?
Did you verify the power-sharing features you want, in the setup app?
That said, my amp-max is limited to 40 amps (group)
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
The universal wall connector is firmware version 25.10.1 and the gen 3 wall connector is version 25.18.0. The gen 3 is about 4 years old, the universal is brand new.
I have not experienced the “panic” yet.
I setup all the power sharing options in the Tesla One app. 60amp circuit, 48 amp max.
BCondrey
Barry
Richmond, VA
The problem I had with the Tesla Gen 3 charger was that when used with an adapter it would overheat and then de-rate down to 24 amps. I ended up installing a separate charger for the Rivian.
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
I did chat with Tesla support today. Not much help. When I get back I need to test charging the Rivian at 10amps. Not sure what that will prove. I already told them that if I force 24amps everything works. If I charge from the gen 3 wall connector first it works. The error occurs when the Rivian connected to universal connector is pulling 48amp and then I plug a car into the Gen3 wall connector.
joem
Joe
Hmmm. I will say that if I set my Rivian to 48 amps, it will only charge for like 30-40 minutes then error out. I’ve heard of alot of people having this issue.
I do not have this issue. I set the amp limit on the universal charger to 40 amp to match my breaker and then the Rivian is set at 48 amp and I don’t bother changing it. Work fine. Gets about 7.1 kWh charging.
captainjp
New Jersey
Gen 2 R1T
I’m curious if it would power share properly with two Tesla vehicles. Do you have two teslas?
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
Up until Saturday I had 2 Gen 3 wall connectors and regularly charged two Teslas at the same time. Loaded balanced well.
captainjp
New Jersey
Gen 2 R1T
Hmm. Definitely sounds like a communication issue with the Rivian. I bet with the UWC two teslas would load balance as well. Have you tried “compatibility mode” through the Tesla app?
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
I tried compatibility mode, same problem. When the Rivian is plugged in second the group power management works fine. I will try two Teslas when I get home from vacation.
PaythePiper
Phx AZ
Model Y, R1S Dual Max
I’m on a full 60a breaker. Here in AZ my garage gets hot. Rivian hates it. Y has no problem
303TP
United States
Rivian R1T; Tesla Model Y
@Lester Green , I have this exact setup and this exact problem. I have also tried switching leader/follower and placing the UWC in compatibility mode. I also have no problem if I set the Rivian to 24 amps. Anything higher than 24 amps and the UWC goes 7 red as soon as the Gen 3 draws current. Everything works flawless if the Gen 3 is under load first.
I suspect this is a problem with the charger on-board the Rivian. I don’t think it reacts quickly enough to the UWC slashing the amps when the Gen 3 goes active and it results in the Rivian charger trying to overdraw from the UWC new balanced limit and there’s the 7 red lights. Just my guess at the moment.
Lester Green
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
Thanks for sharing your experience. I agree with you, but I still have the ticket open with Tesla. When the problem happens I can see on the screen the amperage is dropping in the Rivian, but like you said, it’s not smooth/fast enough.
I am going to contact Rivian and see what they say as well.
PaythePiper
Phx AZ
Mine does it even when the follower charger isn’t used. I can get up to 38a without the errors. I’m in Az though and my garage gets hot obviously. My Model Y never has an issue on either charger
