Range Estimates Reset - No Change
mkennedy1996
Max
North Georgia
R1S, Model X, Model Y
Has anyone else noticed that the Range Estimates Reset process does not have any impact on the range estimates shown? I have tried this several times this year and have never found the values to be different.
Only does anything if you are predictably getting better efficiency than the base EPA ratings. You aren't if the values stay the same. I wish Rivian would have explained this instead of it just being wrong.
mroe
Oakland
If that was the case, shouldn't @mkennedy1996 be seeing 303 miles as that's the EPA estimate for the 22" spec? Or am I misunderstanding?
EPA numbers for the quad are mixed between all-purpose and conserve, but the numbers in the display are if you were to stay in that mode for an entire EPA cycle test. Dual motor vehicles will probably have numbers that match what the EPA result is.
mroe
Oakland
Makes sense - thanks for the info. I have no idea how anyone would be able to figure this out themselves based on what Rivian exposes in the UI.
