Rear wiper replacement - how to get wiper blade off?
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
It's been 18k miles so time to replace the wipers. Front were pretty straight forward but I can't get the back blade off. I don't want to break it and hear it from the wife. Is there a trick I am missing here? I pull the arm away from the glass and push the blade back towards to glass, nothing.
lefkonj
lefkonj
Jeff
New Jersey
Should be able to snap it off without taking off the bolt. Just can't seem to get it done. Front blades done once I saw the push piece to release the arm. Don't want to waste a mobile service for this.
oskeei
Ed
East Central, IL
Tesla Model Y LR, French's Mustard Yellow R1S, Honda Fit
You should at least loosen the bolt, as it's a tight fit between the wiper arm and blade. I actually had to grind a little bit off (1mm ish) off my 3rd party blade as the arm didn't have enough clearance to hook into the blade. Not sure I would have been able to pull the Rivian blade off arm without the extra clearance by loosening the bolt. Pulling was much harder than putting in the new blade.
