aw113sgte
WI
22 R1t
Just like many other cars, they will cut and weld. That' how they replaced the one on my model 3...
It's just unfortunate as cost would be high, alignment of panel likely to not be as good, body filler will be used, corrosion likely at weld seam.
trickflow
Andrew
Tesla Model 3 performance, Toyota 4runner
Absolutely! I near fell off my chair when the body shop charged $15k to do the work. When people build cars like this it is reflected in the insurance. But this seems to be the trend.
jjwolf120
Arcadia
TPA
aw113sgte
WI
22 R1t
You do know the panels are aluminum right?
I did not, most I've heard is aluminum, steel, carbon fiber are all used...but not where they are used.
That said, aluminum also has corrosion issues although generally less than steels.
Canthoney
Andrew
Kansas City
2025 Rivian R1S Tri-Motor, 2022 Rivian R1T
Project Management
It oxidizes, but it won’t corrode so I wouldn’t worry about it.
Right, but it's a little more difficult to weld, and not all shops can weld aluminum properly.
SoCal Rob
Information Technology
Not going to be good if you take a hit to the quarter panel...good luck replacing that whole piece.
It shouldn’t be any worse than other pickups with integrated beds like Chevy Avalanche and Honda Ridgeline.
Actually, I think the only type of vehicle with metal body panels that doesn’t have this issue is a pickup with a bed not integrated into the cab. I don’t recall, did Rivian ever show an R1T where the bed was separated from the cab?
Pretty much every other modern vehicle has the same issue with the rear quarters: SUVs, crossovers, sedans, coupes, convertibles, wagons, etc. Maybe I’m missing something but this doesn’t seem like a situation which is unique to Rivian.
On the other hand, an unpainted metal exterior adds complexity to repairs since you can’t paint over the repaired surface. I seem to recall that’s why some DeLoreans got painted.
I agree, they have been doing this for decades. Even a detached bed has large stamped panels that are welded when repaired and not bolted on. This is not an issue for a professional body shop, just need one that specializes in aluminum, they are out there. Many cars these days have aluminum body panels, I think ford has even been doing it in their F150 since 2015 or 2016.
Cost of repairs these days are more based on designed collision crumple zones than large stamped body panels.
Eager2own
Dan
‘22 Rivian R1T LE
Looks like Costco.
If getting my R1T means I have to walk out of there with a pack of three, I’m willing to do that.
I’d prefer that to Rivian following the IKEA model — here are four boxes, an Allen wrench and a book of instructions.*
* required bottles of wine not included.
Rhidan
They glue/bolt aluminum panels on. You don't weld aluminum.
