Zoomed out map issue?
rpo
Ryan
Bellingham, WA
Finance
I prefer having the nav show the entire route, and that worked great until recently (maybe the last update). Now it no longer zooms in automatically as the remaining route gets smaller. Can anyone else let me know if they are having the same issue?
Same behavior as reported elsewhere.
Reactions: rpo
RivianEC
Tre
IT Specialist
Looks like they made a couple changes. I used to have it set to North and 2D, not it defaults to 3D whenever I open the map, but it goes to 2D when you hit recenter. Strange.
sherold
Indiana
Audi S3, VW Atlas
Yes, I've had the same issue since the last update (2023.46.0). Try putting in a new destination and then canceling the navigation after you get going. That returned it to the normal soon/tracking level.
Reactions: rpo
rpo
Ryan
Bellingham, WA
Finance
Tried this along with a restart and no luck...still isn't zooming in.
And another issue...the charging screen is missing. Can't find it anywhere. Anytime else notice that?
Slide up on the flat bar above your icons to expose the rest of the icons. They can be arranged, it is in the manual, and it will keep the last one used on the right.
rpo
Ryan
Bellingham, WA
Finance
Yep, I'm familiar with the app drawer. It's not in there either. Didn't even show that it's charging when it is, but I can verify it's charging with the app.
Odd, did you try a UI restart?
rpo
Ryan
Bellingham, WA
Finance
I did a soft reset which didn't fix it. Rivian had me do a hard reset with the emergency flasher button last night and that DID fix it thankfully. It was stuck charging at 12 amps on 240, so I was able to get that fixed too. Odd issue.
