electruck4x4
Electruck4x4.com
Whether you are looking for an alternative to the Rivian 20" wheel, swapping out your 22/21's, or just interested in a second set for the snow, we have you covered with new options from our partners at Method Race Wheels and Fuel Off-road.
The Method 315 mirrors their race-proven 103 wheel in a street-legal package. They're constructed out of heat treated A356 aluminum and come in a matte black or machined finish. Both versions boast an industry leading lifetime structural warranty.
Wheel Size20x9
Bolt Pattern5X139.7mm
Offset+18mm
Back Spacing5.70 in
Weight34.01 lbs
Max Load2650
Fitment notes: These wheels require hubcentric rings.
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com MR315_Machined_6_Lug_1000px_1000x1000
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com MR315_Matte_Black_6_Lug_1000px_1000x1000
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com Rivian R1T 20%22 Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Avail
The Fuel Off-road BEAST is also a 20x9" wheel that comes in matte double black. They are a cast aluminum construction pair well with the stock 275/65-20 tire size.
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com b35a79cca55ef0564371e662d5fcf07959c4559dd6d5447f047a923560faa1e7
Wheel Size20x9
Offset+20 mm
Back Spacing5.79 in
Weight40 lbs
Max Load2500
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com 17115436_3766237426950663_825623672392248737_n-
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com 17660010_514517747390971_8087719467489274858_n-
Rivian R1T R1S New 20" Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Available at Electruck4x4.com 16992117_550508946892473_8531174738037764504_n-
So if you were to get those 5 spokes, could you pair them with a tire to make it the same overall size as the 21's so I don't need recalibration?
moosehead
Man, gotta love the extra dish and concavity these show with the lesser offsets. Might be worth the extra poke.
electruck4x4
electruck4x4
Electruck4x4.com
You could in theory, but I honestly wouldn't recommend it. Since your truck does things like calculate range using inputs like vehicle config, you'll need to account for more than speedometer accuracy with a tire/wheel change. Given the lighter weight of a smaller wheel, I'd really suggest having service update your vehicle config to reflect a 20" wheel.
mabowden
Socal
Toby Flenderson
Can we get a side angle photo to see the poke?
electruck4x4
electruck4x4
Electruck4x4.com
Davethadog
YaMa
Trucks, bikes, excavators
Lol if you think this is going to affect range positively.
sub
Rivian R1S, Tesla Model 3
Can you show some pictures with the suspension set to lowest. And confirm that nothing rubs in lowest?
electruck4x4
electruck4x4
Electruck4x4.com
We don’t have a vehicle on hand. (The one pictured belongs to a customer in SoCal). That said, the team at Method worked hands—on-vehicle to ensure a fit (though hubcentric rings are recommended). Having said that, some light tire rubbing may occur if you encounter significant bumps at speed while on the lowest ride height on the stock tire.
dp351
Ariel Atom, R1T
We don’t have a vehicle on hand. (The one pictured belongs to a customer in SoCal). That said, the team at Method worked hands—on-vehicle (as opposed to an on-paper match) to ensure a perfect fit and confirm that nothing rubs with the stock tire configuration.
I’d also like to know if bigger tires fit, rub, or rub badly. I’m sure you don’t have these answers yet.
There’s another thread here showing 295’s on 22” stock wheels, saying they don’t rub. I think 295’s on those Methods would look awesome (yeah I know, range would suffer).
I’m considering changing my config to 21” wheels and then buying a set of 20’s. These Methods might be a good option vs Rivian 20’s. I’d like to know the cost to compare them.
Chirocam
Cameron
Tampa, FL
Chiropractor
Wheel Size20x9
Offset+18mm
Back Spacing5.70 in
Weight34.01 lbs
Max Load2650
Rivian R1T 20%22 Aftermarket Wheel Options from Method Race Wheels and Fuel Off-Road Now Avail...jpg
Wheel Size20x9
Offset+20 mm
Back Spacing5.79 in
Weight40 lbs
Max Load2500
Any pics of the Fuel Wheels on the R1T, by chance?
electruck4x4
electruck4x4
Electruck4x4.com
Yeah, unfortunately I don't think enough people have experimented with different tire sizes yet.
The cost of the Method's right now would be $431.00/ea plus tax. I'm currently offering free shipping on all wheels.
As far as the 21's, I'd consider tire options (they are limited compared to the 22's).
