connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I encrypt PDFs for Boomers
Found this on Reddit, definitely a unique execution.
"Just installed 295/50/22 Nitto Ridge Grapplers on my R1T. No rubbing on flat surfaces even turning on lowest setting. Surely there will be a range impact but unsure yet, will follow up with that info. I know this is not the most practical of setups, but its what I wanted so thought I'd share. The haters will hate."
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T odg0pdxeu53a1 (1)
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T m642oareu53a1
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 38cc3f3fu53a1
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 84f4a7afu53a1
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 16q2bahfu53a1
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 5
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 6
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 7
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 4
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 2
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 3
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T Nitto Ridge Grapplers tires (295:50:22) installed on 22” wheels on Rivian R1T 1
Engineering, Dog Petting
I'm really surprised those tires are actually rated to go on an 8.5" wide rim. I checked. I probably would have gone with the 285 wide ones instead of the 295, but I also have no plans on putting AT/HT tires onto my 22" rims.
DaveA
Looks tough, but street....I don't mind it!
It looks better than I thought it would when I saw the title. I wouldn’t go off road with them, but that’s because I’d be worried a rock would damage a wheel because there’s hardly any sidewall for protection.
I see ski racks on his truck - I wonder if they are just trying to avoid buying snow tires? But I didn’t even see that these are rated for snowy conditions??‍♂
moosehead
Not sure about these Nitto’s snow capabilities, but plenty of AT options with solid if not great snow ability per TR consumer ratings below.
Note the non Riv Pirelli Scorpion AT’s show decent 8.3 snow rating.
https://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=ORAT
True snows for light trucks get snow ratings in the low 9’s. While the Nokian Hakka’s are not included here, IME they are comparably great snows and would show similar outcomes.
https://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=LTSIS
True snows for light trucks get snow ratings in the low 9’s:
That list seems pretty accurate from my experience. The Toyo Open Country AT3s I have on my Tacoma now are some of the best tires I’ve ever had in all conditions, but especially snow. They get an 8.9. The Goodyear Wranglers they replaced because they were horrible in snow are rated a 6.6.
FWIW the guys at Discount tire had recommended a Pirelli AS tire years ago that would be safer in the winter for my Ex’s Volt and it was great with no noticeable hit to range.
moosehead
The TR consumer ratings are based on hundreds of thousands of real miles by consumers and as such are likely the best gauge of tire performance across a multitude of vehicle and performance categories. A few manufacturers are not included such as Nitto and Nokian among others, but they cover the bulk of tire producers.
Given the repetitive tire questions on the board, first time truck owners, and a bunch of swordfights about who has the best snow driving skillz, may be a good idea to post these as a stickey.
connoisseurr
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I've opted for the 22" and will eventually replace with Continental DWS06+ if/when a supported variant is produced.
Would also consider Michelin Pilot Sport 4 A/S.
I think it's really important to go into the survey results and expand them.
BRIDGESTONE BLIZZAK DM-V2
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 1669908936659
FALKEN WILDPEAK A/T TRAIL
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 1669908955165
I certainly don't want a winter tire that only gets an 8.4 for ice traction.
moosehead
Yea, gotta pic proper tool for the job. It’s always about the trade offs.
Proper snow/ice soft compounds wear fast as hell is the only real downside. Likely even faster under the Rivian’s 7k lb bulk.
Below are my wife’s winter shoes from her 4.6k lb Cayenne, Nokian Hakka R2 SUV’s with only two seasons and circa 14k miles. Tread already under 7/32 and both inside and outside shoulders rounded down.
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 741B89C4-2290-4B51-8DD8-2673F599FF56
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 612D1E96-81C6-4F2B-B364-98B8F0F9AE0D
Rivian R1T R1S Nitto Ridge Grapplers tires (295/50/22) installed on 22” wheels on Rivian R1T 000C4928-8845-4DAA-81D8-126225662711
Mathme
Los Altos, CA
High Tech
Those "Grass grabbers" in the original post may do OK in Snow, but if there's any ice below said snow....hello ditch!
ADVNOW
Dom
Wrangler JK, JL 4XE
Manufacturing
I have had Nitto AT and MT tires for years on my jeep they always worked well for their purpose but noise. how is the noise level and handling on the street. I have no doubt they will do well off road.
Bigskyinminnie
Michael
Golden Valley, MN
Merc GL450
I had a set on a Tacoma and they chewed through snow really well. I'll be considering them again on my 20's when it's time to renew worn tires.
Count Orlok
Wisconsin & New Mexico
gross
shumdit
Upstate South Carolina
18 and counting….
I like it. Obviously range and road noise will be necessary trade offs but it looks tough and I am a fan of this decision from an aesthetic standpoint
