kozak79
New Jersey
www.youtube.com
Visual Effects
I use a Quad Lock case on my iPhone for cycling and wanted a mount for the Rivian. I used the designs posted here and made my version that lets you attach the Quad Lock MAG wireless charging head directly to the mount. You can pop the iPhone on and off and it's held very securely while charging.
Print in PETG, it's flexible enough for installation. PLA and ABS will break while installing. I added a threaded hole in the center so that the included screw with the Quad Lock MAG head can be used without any additional hardware. Use a brim and support on built plate, with gear facing up.
https://www.quadlockcase.com/collec...wireless-charging-head?variant=42042648887467
https://skfb.ly/oCVX9 - 3D scan of my dash.
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download 1674669988338
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download 20230125_135006113_iOS
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download 20230125_173733972_iOS
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download 20230125_173729878_iOS
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download Screenshot 2023-01-25 125355
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download Screenshot 2023-01-25 130126
johnkeagy
This is great. I need one but I don't have a 3D printer. May I possibly please pay you to make one? Or perhaps there is a service that will print this for me?
BendyDan
Dan
West Coast
2025 Rivian R1T
I just paid Craftcloud $19.99 to print me one. Don't have it yet, but the process was trivial: Download STL file from here, upload there, pick your finish, and pay. Will report back if this fails me.
the.phd
Las Vegas, NV
2023 R1S Quad Large
Man I wish I knew how to make models so I could make one of these for the left side.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
There is a left-side mount that is really solid, I use it. Actually there are several, I've tried a few, this is the favorite: https://www.printables.com/model/722398-opensourceev-nextgen-phone-mount-for-rivian-r1t-r1
Here I published a revised version of the ball with a few benefits over the original: https://www.printables.com/model/1350812-17mm-ball-with-an-extension-to-get-it-closer-to-th
Here is the installation process:
I have years of experience with car parts in various vehicles. PETG will probably survive where you live, it will absolutely not last one single day here in summer. BTDT. My go-to for car parts that survive, and ultra strong, and look fantastic is Sainsmart PA-CF (nylon carbon fiber filament). You can't hurt it. And you can anneal it if desired, but for car parts I've found it's strong enough as is.
the.phd
Las Vegas, NV
2023 R1S Quad Large
Oh, I've seen those, thanks! But I don't think those would work with Quad Lock's system. =(
SwampNut
Carlos
Peoria AZ
Geek
??? I'm not sure what part you think won't fit? Also in general everything is adaptable to everything with just another ball or AMPS pad. In this case, the QL charger is already a ball mount.
Rivian R1T R1S Quad Lock MAG Phone Mount - 3D Print STL download 1756058396731-hn
the.phd
Las Vegas, NV
2023 R1S Quad Large
The thing in the picture would work, I'll plan on that instead, thanks!
SwampNut
Carlos
Peoria AZ
Geek
Look carefully at the spec, I think the QL is 20mm, and the printed part I linked to is 17mm. But you can buy a 17-20 arm easily. I don't really like QL so I didn't look deeply but in the back of my mind I feel like I saw 20mm.
the.phd
Las Vegas, NV
2023 R1S Quad Large
They have 1" options too.
It's overkill for most of the time, but it beats the phone falling off and bashing into your knee while driving which has happened more than a few times to me.
