ads75
Reading, Pennsylvania
Utilities
If that is what Jeep needs to produce to keep making a Wrangler I am all for it. I wouldn't buy one, but if it helps keep the Wrangler alive I fully support someone else buying one.
It’s not my kind of thing, but competition makes the EV industry better. I’m curious what range they will give this.
popoga
FG R1T, '18 Impreza, '10 Triumph Bonneville
Potato Farmer
I too am all for someone - anyone - else buying this.
Sconces
OC
BMW M2 Comp/Rivian R1T
Hmm nah… this might be like Nokia smartphones back in the day
Grajjie
NYC
BMW M340i, Ioniq Electric, Rivian R1T
Looks pretty good from the side. Front is ok but the rear looks off. That rear glass panel is huge!
Either way I think these will sell pretty well.
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
Looks like an H3 with some LED lights...hideous....
Goose
Raleigh, NC
'23 R1T
Clinical Research
If the price range is $45-65k it will sell very very well. if range and towing are up there with Rivian I will seriously consider one.
Sgt Beavis
Rick
Overpaid Computer Nerd
Overall, I like it. However there is a lot of room for improvement. Jeep needs to rework that grille. Just throwing on some lighting doesn’t really work. It’s too distracting for my taste. The exposed hinges look terrible on an otherwise clean body. I know the doors are supposed to be removable but I don’t think the target audience really cares. IMO that should be saved for the EV Wrangler. Also, it’s going to cause extra parasitic drag, which matters on any EV. Props for getting the charging port location correct. The Recon will be easier to charge at Tesla’s Superchargers.
Of course, the ground clearance is an issue here. If you’re going to put K02s on it, you had better give it some serious ability to go over things. My Rivian R1T has 10“ of clearance at it’s lowest setting and almost 15” at it’s highest. I’m guessing that Jeep is going to put an air suspension on the Recon.
Personally, I think I’d skip this and cross my fingers that the Wrangler EV doesn’t stray too far from the formula that makes it a Wrangler. However, for that to really happen, the Wrangler is going to need the next generation of batteries to let it remain a brick while having sufficient range.
MaskedRacerX
DT
Vilano Beach, FL
'24 BMW iX50 / '24 Jeep Wrangler 4xe
Software Dev / Architect / Product Designer
Stellantis has a modular EV platform, depends on the size of the vehicle, lots of information here:
https://www.stellantis.com/en/technology/electrification
Also some informative info-graphics:
Rivian R1T R1S New Competition: 2024 Jeep Recon EV -- First Real Life Looks 1679927427756
Rivian R1T R1S New Competition: 2024 Jeep Recon EV -- First Real Life Looks 1679927438009
I would guess the Recon would use the "medium" platform? I'm sure the range is a max efficiency based on battery size, but the medium size shows 87-104kWh so pretty stout for that segment.
MaskedRacerX
DT
Vilano Beach, FL
