Ecupip
NC
Rivian, Audi, and 2 Jeeps
I had no issue with the first version. Since installing the second, mine is now prox locking and charging against the schedule. It thinks I’m .2 miles from home now yet showing in the garage on the map. Tried soft reset, deleting and adding the home location, but it still thinks I’m not home. Anyone else have this issue with the second push?
Rade
Rade
US - Rhode Island
radmorningcoffee.blogspot.com
Yes, the updated update got pushed to my R1T while it was in for servicing.
FWIW - Has Apple Music been repaired? The playlist I use for driving... played! I put it on when I left the Canton SC, and it ran without hiccoughing for the near hour it took to wend back the house! If the issues with the app stopping after 2-3 songs has been resolved, I will be very happy! I am dubiously optimistic; the last time they did an update for Apple Music, it did not fix the matter.
Time will tell!
Pacernow
Reese
East Texas
2021 Tesla Model Y LR AWD
Semi retired
All,
I have a Tesla L2 wall charger that I used with my R1T the last 13 months. On very rare occasion the adapter will get warm and go from 11.2 kwh to 5.2 kwh. I have 3 adapters made by different companies. Since this second update the R1T charges at 11.2 kwh for less than an hour and then drops to 5.5kwh for the duration. I have used all three adapters and the same happens with each adapter.
Before the update the Rivian would charge at 11.2 kwh for the entire charge cycle. Any thoughts? Any suggestions?
tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
All,
Which adapters do you use? I use a Tesla Wall Connector as well with a Teslatap Mini 60. I will be charging tonight.
Pacernow
Reese
East Texas
Semi retired
tate16t,
I have the EVDANCE, Lectron, and DIVOME adapters.I started charging about 5:00PM Texas time with the DIVOME adapter attached to the charger. At 6:45PM I checked the Rivian app and the charging had throttled back to 5.5 kwh from 11.3 kwh. I changed out the adapter for the EVDANCE adapter. With the EVDANCE adapter attached the charging went back to 11.3 kwh. After reading your comment I looked at the app and the R1T was still charging at 11.3 kwh. So for the last almost 2.5 hours the R1T has been charging at 11.3 kwh. Big improvement compared to the last two nights.
tate16t
Robert
Car Enthusiast
tate16t,
The same behavior was reported in this thread, but it went back to normal the next charging session, strange. I usually charge at a consistent 10.8.kW on the Rivian and 11.2kW on the Tesla. I’m charging our Tesla at the moment so may not charge the Rivian tonight but certainly tomorrow.
Pacernow
Reese
East Texas
Semi retired
tate16t,
Just checked the app and the R1T charged for 2 hours and 23 minutes at 11.3 kwh. When I charge the R1T at home it will charge at 11.2 or 11.3 kwh. Which Tesla do you own? I had a 21 Y AWD LR before trading it in on the R1T. Hope your charging goes well.
mkhuffman
tate16t,
I would like to help, but I don't know what the issue is. Can you clarify?
tate16t
Robert
Car Enthusiast
tate16t,
A little fluctuation is normal. My Rivian sometimes jumps to 11.2. The 5.5 kwh you were getting is not normal but seems it resolved itself just like @Goose experienced.
We own a 22’ MYP as well.
Goose
Raleigh, NC
'23 R1T
Clinical Research
I’m using a j1772 charger, no adapter
Pacernow
Reese
East Texas
Semi retired
mkhuffman,
My charging kwh went from 11.3 kwhto 5.5 kwh on Tuesday evening after downloading this updated OTA. It would start at 11 kwh and after an hour would drop to 5.5kwh. It did this every evening while charging. After I changed adapters last night it charged 2.5 hours at 11.3 kwh. Maybe it has rectified the issue. I am charging now so I will watch the kwh and see if there are any dramatic decreases. Thank you for your response.
tate16t
Robert
Car Enthusiast
mkhuffman,
Was the weather hot that day?
Pacernow
Reese
East Texas
Semi retired
tate16t,
The temperature was in the mid 80's.
Pacernow
Reese
East Texas
Semi retired
All,
The R1T has been charging for 2 hours at 11.3 kwh.
