30-day no-use // how much battery drain?
Glembi2
Vienna, Virginia
R1S, Genesis GV70, Civic
Patent attorney
Update:
we flew out on the evening of June 30, and the R1s was showing 303 miles of range.
In the app this morning - July 12 - with the Shipping Mode On, it’s showing 296 miles of range.
if that’s accurate, and is a comprehensive representation of total battery drain, I was clearly worried for no reason.
Wow - that was a tiny drain!
Just out of curiosity, which battery do you have? I believe the 2025 standard battery is LFP while the large and max are NMC. If you have the standard battery, i understand Rivian’s comment about charging to 100% (LFPs are happy being charged to 100).
While a single cell NMC is happiest at 50% charge and are shipped that way, I have to think Rivian knows its battery control system better than anyone. If they say charge to 100% for long term storage, I would do it.
maca
Igor
Boston
2025 R1S / Dune
healthcare
It’s a Dune (tri motor) so the larger battery.
Mathme
Los Altos, CA
High Tech
Gen 1 Large and I lose about 1%/day when either parked at home or at the airport lot. I have GG off in both locations. So if I leave, I'll charge to 80% and expect it to be in the upper 50s when I get back. I haven't set shipping mode.
As others have said, If you have a regular 110 household circuit close by, you can also set your charge level to 50 or 60% and then leave the truck plugged into the travel charger. The battery will then drain until that 50 or 60% and then stay there.
hudesigns
Jim
New York
2026 R1S dual max performance
I wonder if phantom drain will become less after Connect+ expires. If so, it’s one good reason not to subscribe. My 2026 dual max averages daily parked loss about 1.8 kWh, which is over 1% of 140 kWh battery, for doing nothing.
MidnightRivian
I am getting 2% drain per day at the airport with everything on.
RomanN
Austin, TX
2025 R1S Tri Max
I went to Europe for 10 days. Left my Tri in the driveway at 100%. Came home to 79%. Cameras were on and there is probably a lot of motion because my neighbor's driveway is close to my Rivian.
10BladeDad
KB
Frisco, TX
'08H2, '13 MDX, '25 Highlander
Live
Went on holiday 13Dec parking my Gen2 R1S TM @ DFW airport at 0530 with 78% SOC. Family & I returned 26Dec @1500 with vehicle at 67% SOC.
Rivian R1T R1S 30-day no-use // how much battery drain? Depart
Rivian R1T R1S 30-day no-use // how much battery drain? Return
The avg. temp in DFW during this period was 59 degrees. Granted, it wasn't as cold as other parts of the country. Nevertheless, I was pleasantly surprised to have lost <1% SOC per day with GG on(& pre v.46.0 update). First time ever parking my TM outside overnight.
hudesigns
Jim
New York
Parked in my own garage for past 4 days with nothing on, no motion or live cams. Where’s almost 15 kWh gone?
Rivian R1T R1S 30-day no-use // how much battery drain? IMG_8897
Rivian R1T R1S 30-day no-use // how much battery drain? IMG_8898
