Mars Adventure Gear
Fremont, CA
Rivian R1S, Rivian R1T
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750359360367-xj
When it comes to EV overlanding, two things matter most: weight and aerodynamic performance. That’s why we developed the Mars Aeroblade, quite possibly the world’s slimmest hardshell rooftop tent. The result? Longer range, quieter rides, and less drag. And yes, it’s compatible with non-EVs too, as long as they support rooftop tent mounting.
OPTIMIZED AERO PERFORMANCE
It’s not just about looks—we ran CFD simulations to understand what makes a rooftop tent truly aerodynamic. With only one-third the drag force of competing models, the result is minimal EV range loss, improved fuel efficiency, and significantly reduced wind noise.
CONSTRUCTION & MATERIALS
  • 6-series CNC-machined billet aluminum latches
  • Extruded aluminum frame with UV-resistant coatings
  • Triple-layered fabric: breathable, 100% waterproof, and condensation-resistant
  • Optional insulation inner tent (sold separately; included in the Adventure Kit)
  • Optional accessory crossbars (sold separately; included in the Adventure Kit)
  • Integrated foam mattress, no inflation required
SPECIFICATIONS
  • Exterior dimension (closed): 87 in x 52.2 in x 3.48 in
  • Interior dimension (open): 82.2 in x 46.5 in x 50 in
  • Weight: ~110 lbs
  • UPF: 50+
  • Hydrostatic head:18890 (mmH2O)
  • WVTR: 10900 ( g/(㎡.24h) )
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750359630588-qq
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750359681193-eq
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750359924062-ea
We also have optional accessories available for the Aeroblade.
Mars Aeroblade RTT
Mars Expedition Roof Rack System (R1S)
Thermal Insulation Liner for the Aeroblade
Accessory Crossbar Set for the Aeroblade
Flexible Solar Panel for the Aeroblade
Tip: We have a bundle discount if you opt for the rack + Aeroblade combo.
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More dsc09445-
Huge thanks to everyone who supported and placed an order when we first introduced the product. The first batch is now en route, and most customers will be receiving theirs shortly. Meanwhile, our second batch is already on the way to our distribution center. Stay tuned!
Low-key announcement: more exciting camping gear coming very soon :)
MARS COMMUNITY
Mars Adventure Gear is and will always be community-driven. We believe the best ideas always come from those who use the products, and that spirit pushes us forward to create even better products that enthusiasts will love and want to use daily. Community members receive exclusive discounts.
Join now
Follow us on Facebook, X, Instagram, and LinkedIn.
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750359335057-x5
What's the process for actually getting into the tent?
Mars Adventure Gear
Mars Adventure Gear
Fremont, CA
You jump into it! Just kidding...there's a telescoping ladder that comes with the tent!
Rivian R1T R1S Mars Aeroblade: 3.48" 110 lb Ultra-Slim Rooftop Tent for Rivian R1S and More 1750361565768-s2
Ah, okay, you still climb in through the side. Wasn't completely obvious to me.
FooF
FooF
Mountain View CA
foof.me
2022 R1S Launch Green
DJ
I have an Overland Ruff Rax on a R1S. How would you mount to this type of rack?
Mars Adventure Gear
Mars Adventure Gear
Fremont, CA
FooF
FooF
Mountain View CA
foof.me
DJ
Thanks for the guide its shows good detail on how to mount to a set of crossbars but no details at all on how to mount onto a platform rack. I am guessing you would put some 90 degree angle brackets on the slots under the tent and connect to the crossbars of the rack which would be hard to reach with the tent on top of the rack. Can you show pics of how you mounted the tent on the Rivian in your marketing photos? Or was that just a photoshop mounting ;) ?
Looks to me that you would mount the included mounting bars to bottom of tent, slide bolts through slot in these bars. These bolts would then be situated in pairs perpendicular to your factory or aftermarket crossbars and secured with the silver brackets and nuts.
FooF
FooF
Mountain View CA
foof.me
DJ
That would add an extra inch to the height of the tent which kind of defeats the purpose of being the slimiest tent and probably make it too tall to get into my garage. An inch gap would still make it very hard to access the mounting bolts. Maybe that is why they have big holes on the side of the mars rack to get access to the mounting gear?
Mars Adventure Gear
Mars Adventure Gear
Fremont, CA
Lester Green
Beetlejuice
Chicago
2025 R1S Tri Max
Thanks, I did read through that, but I wasn't super clear on how the tent attaches to the Rivian branded cargo crossbars. It looks like the tent bolts to the Rivan cargo crossbars, but that seems less than ideal.
Mars Adventure Gear
Mars Adventure Gear
Fremont, CA
There are mounting bars on the bottom of the rooftop tent. Slide the T-bolts into these bars and tighten them to clamp onto the Rivian crossbars. You don’t bolt the tent directly to the cargo crossbars.
Carscott
Christopher
Canada
Honda odyssey toyota Prius v
Hey for those that have this how is the clam shell for water proofing when driving in the rain?
