Starlink for Overlanding Connectivity
cdement
Craig
Missouri
Bronco Wildtrak
We’ve had our R1S for about 6 weeks. I recently got a Starlink mini for it because cell service is spotty in my area. My plan was to mount it inside in the 3rd row glass with one of the many suction cup mounts. I can’t get it to work from the inside through the glass. I think Rivian might have added some layer to the glass that prevents the signal from going through since it works fine when I put it on the roof. For reference it’s a Gen 2 built in March ‘25.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Correct, the Gen2 glass has metal in it. You cannot mount it inside.
waitingonanr1s
Works great mounted on the crossbars. I really enjoyed being able to stream music without hiccups driving on I-70 across southern Utah. I continue to be amazed by Starlink. What a great product.
KBabione
Kevin
Lititz, PA
2023 R1S Quad (8/23)
An update after using my Starlink Standard at two tailgates...
It works beautifully! I just set it on top of our R1S and plug the router into a powerstrip (which also powers the TV) inside the R1S and voila! We have internet and are able to stream football games to watch while we tailgate. I did buy a 15' cable (the 50' cable that it came with was overkill for my use case) and bought a bag to transport the entire setup. It's coincidence, I'm sure, but I've used 11GB of my 50GB monthly at each of the two games streaming (total "consumption" of 22GB).
I'm happy because I can watch other games while we tailgate and my wife is happy because she joins my "Tailgating" WiFi network and is able to use her phone as if there aren't 120,000 other people trying to use the same cell towers.
cdement
Craig
Missouri
Bronco Wildtrak
I wonder if this means all glass is capable of the dynamic glass roof but it’s not enabled in the software 🤔. If the hardware is capable maybe a pay option to enable it?
SwampNut
Carlos
Peoria AZ
Geek
I don't know if all of them have metal, I don't know what roof options there are besides the electric darkening. For sure, I've seen people simply reporting that Gen2 roofs don't work with Starlink or even with an inside-glass cell antenna. I have no other info on it. There may be some that do work, but I've never seen a post about a G2 working with the inside antenna. I didn't mean to suggest that ALL of them fail for sure.
the.phd
Las Vegas, NV
2023 R1S Quad Large
Older thread, so feel free to kick me to a more recent one if it works better, this just came up when I searched.
Looking at mounting my mini on the R1T roof, and using my switch to power it that I also use for lights. Do I need to put anything between the switch and the mini or can I just run the power cord straight from the switch assuming output is enough?
JM.
Jon
France
Tesla, Energica
You need at least a compatible plug and wire from the switch. The Mini *can* run on 12v and some people say that's fine, but others report a problem. The common recommendation is to run a 12v to 24v or 48v converter in line. All of this is commonly available on Amazon.
Michal
Michael
NYC
R1T LE
You will need to use of of the step up adapters to hardwire: https://amzn.to/3PsOVKr
Here is a referral code for a free month of service:
https://starlink.com/residential?referral=RC-DF-11042467-41924-91
Fax
Joe
Las Vegas, NV
Starlink newbie here...I just set it up and tested it in a local park yesterday before its "debut" tailgating at the Penn State game tomorrow. As I was setting it up the graphic clearly showed that the bottom edge of the dish (I have the Starlink Standard) should be facing north. I can't imagine that would matter, but wanted to ask.
Also - Do they sell a shorter cable to connect the dish to the router? I don't need 50' to go from my roof to the interior of the R1S.
What specific bracket do you use and how do you route the cable into the R1S?
KBabione
Kevin
Lititz, PA
My first two tailgates I just used the kickstand that came with the Starlink (I have a standard). I bought the official Starlink Roof Rack Mount and it worked well with our Rivian crossbars, but I pulled it off for this year. I just don't need it to be mounted like that and sometimes it wasn't facing the optimal way when we parked so I'd have to switch the crossbar orientation. I went back to the kickstand, but I did put some non-slip tape on it so I can just put it up on top of our glass roof without worrying about it.
In terms of running the cable, I just bring it up through the bottom of the R1S tailgate. It's crazy, but I'm able to run all of my extension cords (and the Starlink ethernet cable) through that and close it up without pinching the cables. Let me know if you don't know what I'm talking about and I'll see if I have a photo. Sadly, our R1S is in the SC right now (and is likely to be there for a couple of weeks while we're waiting for parts) so I can't take a quick photo and show you.
Redmond Chad
Redmond, WA
HERE is a video showing how to run cables out the tailgate of an R1S. Handy, I've used it too.
tobidogger
Whatcom
R1S / Jaguar XE-S / Misc.
Snowboards...
I live in B'ham, WA and I spend every possible moment away from other humans in the mountains and woods here and in BC - recently almost nightly I bolt from work with the dogs and food and hang out/hike until very late. I have a starlink mini. I have done 2 things, I installed PD power in my front trunk and in the center console of the truck so I can power everything. In the front trunk I have a 12v cig adapter and a PD C and A, in the center I have 2 high power pd A/C and a cig on a circuit breaker/power switch. I have my starlink in the trunk in a case from https://veritasvans.com/. It takes me maybe 90 seconds to get it out, suction cup it to the truck and align it. It is funny to me how good I have become at knowing which way to point the truck to get it on the first try. But one thing I have noticed is that even when it is not perfectly aligned I get 90/20, which is PLENTY for a normal human. I often watch movies when in the woods doing technical work (I am working on a sensor network for backcountry snow condition and sometimes I need internet to work on the code to debug on the spot)
All of this is in a small bag in the front trunk, I use a unifi travel router to VPN me back home in seconds.
While I get the notion to bolt this thing to the roof rack and such, I never use my rack. Me couple people and dogs...we fit in side the r1s fine :) hahaha it is larger than 3 of the cars we had as a kid with a family of 5, so, ya know your milage may very. You can bolt the case I got to the roof rack if you want.
I have to say as an engineer / nerdy type / gear freak both the powerwerx and veritas van stuff are freakin' bomb proof.
Oh I got these little caps for the ends of my usb-c cables just to keep the rocks and such out of them, just look on amazon.
KBabione
Kevin
Lititz, PA
After a July 4th storm rolled through our area and knocked down a bunch of trees, friends of ours lost their internet (and cell coverage is weak so they can't use their hotspots) so I activated my Starlink Standard and took it over and set it up for them. Voila! They have internet again!
I typically only use my Starlink for tailgating at football games (Sept - Dec) and the rest of the time it's in standby mode for $5/month (although I think it's going to $10/month). Well worth it - when we first thought they would be without internet for just a day or two I set up the Starlink and they had 2 MPS service - which worked well for texting. When they realized it would be a lot longer I did the activation.
SwampNut
Carlos
Peoria AZ
Geek
Standby went to $10 a month or two ago and it’s 500 Mbps rated though we normally see 600-700. Limited video, fine for many other uses.
