Truck bed tent fit for R1T
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
I'm considering getting one, but the dimensions of the bed are rather unusual. Wondering if anyone has used one and has experience with fit.
The bed is one of the shortest on the market with the tailgate closed. But the tailgate is huge. I'm looking at the Gladiator in comparison because it's at least supported by some of the tent vendors.
Rivian:
Bed, 54"
With tailgate total, 83"
Gladiator:
Bed, 60"
With tailgate total, 81"
The width at the bed rails is radically different however. Rivian 51 and Gladiator nearly 59. But the wheel well width is vastly less on the Gladiator.
I think what really matters is the total length. This product looks good, with a good price, and is rated for the Gladiator. Specs say up to 3" variation is ok:
https://www.joytutus.com/products/semi-automatic-truck-bed-tent-with-awning
Cycliste
Solano County, California
Amateur aero weenie
I’ve thought about just sleeping in a bivy under the manual tonneau cover with the tailgate open. My problem with bed tents and roof top tents is your vehicle is immobilized while the tent is set up. I’m also lazy about time spent setting up camp. My favorite form of camping is cowboy camping so I can see the stars. It really helps to be in California where we have a too long dry season
SwampNut
SwampNut
Carlos
Peoria AZ
Geek
Same, I may try just my pad and bag there and see. I'll only do fair weather camping.
Same, the one I linked to is their semi-auto which is pretty fast to set up.
Cycliste
Amateur aero weenie
kewlasu
Maine
2022 Rivian R1T LA Silver Adventure Large Pack 21"
Rivianero
Brent
San Marcos TX
2022 R1T quad large
We have an earlier version of that tent from the same vendor.
https://a.co/d/089vWhNB
At $80 we have no regrets.
Is perhaps a 6" long in length, but I would rather have that than too short. Have used it a bunch, but do end up using a conventional ground tent when we spend more than one night.
I'm intrigued about the new mechanism to quickly pitch the tent. It would be a boon if one could leave the tent attached, close the tonneau, and drive to the next overnight spot. Let us know if that is doable. It would give you most of the benefit of a rooftop platform without the cost or wind resistance.
FWIW we also got a relatively cheap camp mattress that fits the bed well.
https://a.co/d/03BnnZiN
Have used it extensively in the truck and our boat. Still holding up well and makes a big difference. Does not fold up very compact.
Happy camping!
tplociniak
Todd
NE PA
R1T, VW Atlas
Construction Manager
Little bit of a different approach and something I planned on trying. Get the benefits of the truck leveling, close to electrical if needed in the bed, plus easy to setup and take out of the bed if you wanted to go wheeling or use the vehicle
Tent Cot
Noplacelikeloam
Andy
Portland
Creative management
Only in an 5.5' F150 bed. Used the Napier Backroadz Truck Tent. Was fantastic. BUT, you have to empty your bed obviously. Ended up disliking that part but otherwise was great.
Noplacelikeloam
Andy
Portland
Creative management
Tent Cot
That is nice! So easy and portable.
SwampNut
SwampNut
Carlos
Peoria AZ
Geek
I should have mentioned that yes, there's one specifically stated to fit, and no, I'm not giving them $310 for it. I'll tent it on the ground and risk the scorpions and snakes. But it's just a generic tent where they said it fits R1T and Gladiator, which is why I used the Gladiator as my measurement/comparison.
Thanks, that is SUPER useful info. Does it hang over? Or what happens with the extra material. Do you think the smaller version would come up short (I think no, unsure).
Tent Cot
I have something similar for motorcycle camping, however, this is so that I might convince the wife to actually camp overnight without our travel trailer.
DeanB1452
Dean
Milpitas, CA
'22 R1T LE/LG/BM
IT Administrator
I have used a different model from Joytutus for several campouts for the past few years: https://a.co/d/0e1yxpwK
It fits the bed and tailgate fairly well. One drawback is that the flap at the cab window has nowhere to go since it is designed to go over a regular truck bed that is separated from the cab. The first night that we used it, it rained on us and water pooled up in that section. It didn't leak into the tent, but it eventually drained off the sides. Stick something like a pool noodle there to help it run off.
When we were on the go each day, I would partially collapse the tent...unhook the straps, fold the tent poles in half, and let it set in bed and cover the tonneau cover as we moved on.
Don't get a thick air mattress (seen in one of the pics) as it's too bulky in there. We ended up getting a 3" mattress which worked out perfect. https://a.co/d/0bPWi3le
Rivian R1T R1S Truck bed tent fit for R1T IMG_2557
Rivian R1T R1S Truck bed tent fit for R1T IMG_2580
Rivian R1T R1S Truck bed tent fit for R1T IMG_1687
Rivian R1T R1S Truck bed tent fit for R1T IMG_1505
Rivian R1T R1S Truck bed tent fit for R1T IMG_3186
Rivian R1T R1S Truck bed tent fit for R1T IMG_8536
SwampNut
SwampNut
Carlos
Peoria AZ
Geek
Ok, thanks, this really confirms that the short/compact version is about perfect here. I'm not sure how thick our two air mattresses are, I'll do a driveway campout to test it all.
Mellowyellow
This is cool. I had no idea such products even existed. You learn something new everyday
Soju1
Michael
Bay Area
I have the c6 rev tent with the platform to use as a RTT. The nice thing is that the tent and the platform can be separated so I can easily pull the tent off the platform and stake it to the ground and use it as a ground tent. It’s 84” long so it would stick off the bed an inch if you wanted to use it as a bed tent. The tent portion weights 25lbs. https://c6outdoor.com/collections/rev-roof-top-tent-colllection
