900 mile towing trip
Luxus
Walter
Niles, IL.
2026 Rivian R1T tri; 1973 Buick Century Gran Sport; 1974 Buick Lesabre conv
Mechanical Engineer
I just got back from a 900 mile round trip where I towed another car with my 2026 R1T tri motor. Towed trailer and car was about 7000 lbs (per the truck). Drove from Chicago to Bowling Green, KY and back. Just used a ball hitch, did not use a WDH like Rivian recommends for trailers over 5000 lbs.
Overall the Rivian performed well, pulled the trailer fine. My consumption was 1.3 mi/kWh while pulling trailer. I didn't try to push the limits of how far I could go, but I could do an hour and a half or so before having to stop for recharging. Sometimes I stopped sooner due to what the route planner told me. I used the Rivian route planner for the trip and it worked well IMHO.
Charging could be interesting due to towing a trailer. On my trip there were no trailer friendly chargers. So I had to do a lot of creative parking so I could charge and not block the area around me with the trailer. Only once I had to unhook to charge. Most of the chargers I used were Tesla. As much as I am not a fan of Tesla, I have to admit that their charging stations were fast, reliable and had a lot of chargers. The stations were surprisingly busy during the day although I never found myself in a situation where there were no open chargers. My only complaint was the charging cables are way too short. They really need to be a bit longer.
I had one real issue with the truck. On the day we were to head back home, the truck would not recognize the trailer was connected. So no trailer brakes or lights. I called Rivian and I was able to talk to someone on a Sunday morning which I very much appreciated. They had me do a hard and soft reset but nothing worked. In the end, I just went on with my trip as is as I needed to be back home that day. We stopped for a longish brunch and when we got back, the truck had fixed itself. Go figure.
One final comment, while towing on the highway I would feel a 'jerky' sensation when the truck and trailer went over bumps in the road. I believe that was coming from the interaction of the truck and trailer at the hitch while going over the bumps. I'm going to guess that is why Rivian wants you to use a WDH for trailers over 5000 lbs. It probably mitigates that sensation.
robd
R1T; Tesla Model 3
I towed our ~7000 lb Airstream about 2300 miles in March and April. I used a Shocker 14K MaxAir hitch to soften the ride and help reduce shock to the trailer. I was really pleased with the smoothness of the ride.
I haven't done A-B comparisions with my rigid hitch, but I may do that this summer. The Big Truck Big RV youtube channel has several videos testing different shock absorbing hitches for anyone looking for more info. Note, if you do get a Shocker hitch, you also need the spacer block to get optimal alignment.
I looked into the AirSafe hitch, but it wouldn't fit based on my measurements and correspondence with the company (who were great BTW).
I hope to post a trip report on my towing and charging experience soon.
Anti-rattle clamps usually help quite a bit with that, I also run one of the Curt rocker-balls to absorb more of the banging around since regen changes the braking equation a lot.
antimatter
Lloyd
Minneapolis, MN
Honda Ridgeline, Honda CR-Z
Chief Compliance Officer
Yeah, I think adding an anti-rattle device might help with the jerky feeling you were getting. There's a little slack between the receiver the hitch stinger that can move around when you're accelerating or going over a bump. It used to make an audible 'thunk' in my Ridgeline, so I added the anti-rattle device when I bought my R1T and it eliminated the noise and jerkiness.
2kwik4u
Michael
Western NY State
It's the truck that's doing the jerkiness. I complained about it the first time I towed with the Rivian and was essentially told I was wrong and that Rivian was the best towing vehicle ever. I run a hitch with an anti-rattle feature, and I've had vehicles where that was the problem, this isn't it.
I think it's poor suspension tuning, but am not 100% certain. It definitely takes away from the experience.
here's my initial experience. https://www.rivianforums.com/forum/...ian-generally-underwhelming-experience.47235/
I found the ride to be exceptionally "jerky" as well. Almost like the cruise and the trailer were fighting each other. In particular on downhill sections where there was no "dead band" for the system to absorb changes. I could feel, and watch on the display, how the truck was rapidly changing from adding to removing power from the driveline. It was bad enough that the open top drinks in the cupholder were sloshing around. Not sure if that's a function of how the hitch works, or if the truck is expecting the trailer to have brakes, or if there just needs to be more allowance for speed variance while towing.....but it was mildly frustrating at best. Wife was complaining because she couldn't read her book (I know, first world problems here) because of the "jerkyness" of the ride. Beyond that weird calibration issue, the suspension was overly harsh. We tried all 3 settings and none of them would dampen out the fore/aft up/down ride harshness. It reminded me of some times I've driven with a loose or "rattley" hitch assembly and the whole system develops a kind of resonance. Something like an expansion joint or similar disturbance would calm the system for a few moments, then it would come right back. If it was like this on the 4-days of towing to FL and back, the family would be considerably pissed at me. It's really pretty awful.
antimatter
Lloyd
Minneapolis, MN
Funny, when I hauled my camper back from Billings MT to Minnesota I didn't have any jerkiness or other issues. Maybe its just your particular vehicle? Any others who tow care to comment?
I'm going to be taking off on a short camping trip in a couple of weeks, and I'll make mental note to check on the 'feel' of the towing experience.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
I get some jerkiness, but I think I don't have my brake gain 100% dialed in either. Haven't taken the time to get a nice, straight & empty road that I can do 25mph on for a while for testing.
I also have anti-rattle on my ball mount (in two places, thanks to it being adjustable!).
robd
R1T; Tesla Model 3
@2kwik4u I went back and read that thread. The jerkiness sounds frustrating and perplexing when others don't experience it. I forget, did you experience it consistently on all/most road surfaces and speeds?
I have experienced a fore-aft oscillation a few times towing the Airstream and I attributed it to the road surface. The reason I'm thinking that way is I experienced an oscillation before with a car (Acura TL, not towing) -- always on the same stretch of road. I suspect undulations in the road generate a resonant frequency with the suspension. Anyway, in the 20 miles of so of the fore-aft oscillation, I tried slightly different speeds (50 - 60 mph)and changing the ride firmness -- none of them helped. Eventually the oscillation stopped after the road surface changed.
2kwik4u
Michael
Western NY State
It was felt most at highway speeds on concrete surfaces. The expansion joints that are regularly spaced are certainly part of it. Also downhills seemed to throw the cruise control into a fit. It can't decide if it wants to brake or to accelerate, and there is nearly no "coast" throttle position it seems. The truck just struggled really hard to find a good "steady state" on the interstate.
I've had this boat for 9yrs now and towed it with probably 10 different vehicles. The Rivian is the only one it's done this on. My Q7 (with a shorter wheelbase) was quite smooth on this same stretch of road, so it's something with the Rivian.
Between the oscillations and poor suspension tuning, no adaptive cruise while towing, and the just generally OK power (I have a dual motor, non-performance) it's just an OK towing experience. Honestly much prefer the Q7 I had before it, and the Sierra before that. I'm really trying not to hate on Rivian here, but the more I use it as a tool the more like a toy it feels. Anytime I ask it to do work things, it presents a ton of compromises or otherwise lackluster performance.
It adventures really well, but works just kind of OK.
Luxus
Luxus
Walter
Niles, IL.
Mechanical Engineer
I have a gen 2 and the cruise control worked fine for me. No complaints outside of having adaptive cruse would have been nice. For the brief period of time when the truck did not recognize the trailer, the adaptive cruse did work and I don't understand why they don't allow it during towing.
