svet-am
Tony
Broomfield, CO
R1S (Launch Edition Preorder)
Embedded Systems Engineer
Since there was a similar thread for the R1T I decided to start one for the R1S bow that there are increasingly more of them being delivered.
So, whatcha want to know?
shamoo
Rivian R1S, Porsche 911 GT3
Cybersecurity
Can the rear hatch be closed manually?
Rather, should it be? When asking at the Venice, California hub, they didn't know but they felt because there was a lot of resistance, you should NOT manually open/close the hatch. I did move it a few inches manually, but there was a lot of resistance so I stopped.
Asking because would like to know if it is possible to manually close the hatch with the liftgate down (to carry something long sticking out). I know the auto-close will not work if the liftgate is down.
svet-am
svet-am
Tony
Broomfield, CO
@shamoo - can you define you use of hatch and liftgate here? The R1S has a split rear with a small tailgate and a large liftgate. The liftgate can definitely be operated pseudo-manually just but pushing hard enough to get the automatic mechanism to release. The only caveat is that it will store the location where it turned over control to manual as a max/min for the automatic operation until you do a complete open and close cycle on the center display
shamoo
Cybersecurity
Hatch = the trunk/section with glass/part that goes up.
Liftgate = the small piece that folds down
That's interesting, so you CAN move the "trunk" manually. The resistance I experienced was much firmer than other electronically actuated trunks so I was hesitant to keep moving it.
So that being said, are you able to leave the rear liftgate folded down and manually close the hatch/trunk all the way? Leaving a small space where some long pieces of wood can stick out.
For example, this is not my car but I used to have an X5(M) and I could do this. Can the Rivian R1S do this too?
Rivian R1T R1S Ask us Rivian R1S owners ANYTHING [AMA]! 20140111_150923
PNW 02
Multiple
What is the height of the “hatch” (as defined above) closing button at standard ride height?
kyunam
1999 LS 400, 2023 Rivian R1S
not sure what I'm doing
Are you happy with your R1S?
svet-am
svet-am
Tony
Broomfield, CO
@shamoo - ok, it was just a taxonomy issue. The liftgate is the part that goes up. The tailgate is the part that goes down.
https://wikidiff.com/tailgate/liftgate
So, yes, the liftgate can be operated manually if you override the pressure. The tailgate is always manual.
svet-am
svet-am
Tony
Broomfield, CO
Absolutely 100%. Glad every day I stuck with it and waited versus getting an R1T sooner. It just fits my needs and lifestyle better.
svet-am
svet-am
Tony
Broomfield, CO
Out running errands but will measure when I get home. Stay tuned to this reply.
In standard ride height, it's 78" above the ground.
Rivian R1T R1S Ask us Rivian R1S owners ANYTHING [AMA]! 1665535368272
hbkdinobot
Daniel
cdewf99(
Tesla Model X
Does the rear hidden storage container/spare tire bin double as a ice cooler with drain plug like the R1T?
svet-am
svet-am
Tony
Broomfield, CO
No. It is fabric lined.
PNW 02
Multiple
Thank you!
astonius
Cars
Can you press and hold the liftgate button to set the power open height?
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
How much storage space with 3rd row up? Does the cargo cover still work with the 3rd row up?
svet-am
svet-am
Tony
Broomfield, CO
