Cold weather driving efficiency - Gen 2 LFP vs. NMC?
evthree
Jason
Milwaukee, WI
2025 R1S Dual Standard
Institutional Investor
Hey all-
Curious about whether there is a driving efficiency difference (miles/kWh) between the Gen 2 Dual Standard (LFP) battery and the Gen 2 Max (NMC) battery in cold weather.
I realize that there is a range difference based on the different kWh sizes of the two batteries, but wondering if driving efficiency (miles/kWh) is similar or different between the battery chemistries.
Thanks for any insights, all! Love the value of my DS LFP. Slightly more winter range anxiety than I have had with past EVs (Model 3 and Model Y), and I am trying to understand how much of that is specific to the LFP battery vs. Gen 2 battery heating/efficiency generally.
evthree
Jason
Milwaukee, WI
LFP batteries have its advantages, but doing well in really cold weather isn’t one of them
https://www.large-battery.com/blog/nmc-vs-lifepo4-battery-low-temperature/
Thanks for the link. I have read similar summaries, and they are always helpful.
That said, what I am specifically wondering about is LFP vs. NMC based on the way that Rivian implements and manages battery temps in the Gen 2 R1S.
For example, if I am averaging 1.8 miles/kWh in 20 degree (Fahrenheit) temps in my LFP Dual Standard, would I be getting substantially better efficiency if I had opted to pay $25K more for the Max battery?
I understand that the available capacity may decrease more with LFP, but I am specifically wondering about driving efficiency with whatever capacity exists.
Has anyone seen any data on that?
Gen2R1T2025
Tennessee
2025 Gen2 R1T
I see about 10 to 20% drop in winter efficiency compared to summer for my duty cycles. 2025 Gen 2 R1T DS. Lifetime Aggregate is around 2.9
Audiotek
Pete
Central New Jersey
Audio Tech
My configuration is a 2023 Gen-1 R1S Quad Large Pack (NMC chemistry O.G. version). 22 inch Pirelli Scorpion Tire set to 48 PSI
I returned from Schenectady NY to central New Jersey on Saturday 1.24.2026.
Outside temp minus -20 degrees Fahrenheit
Travel distance 189 miles
RIS miles used 265
Used driver+ w/ conserve mode.
Driver+ Set speed 74mph
Longest stretch 113 miles in a mostly straight line
Height setting- auto
Ride feel - soft
Summary is that I used 29% more battery miles to travel the actual distance .
This rhymes with what others have reported in terms of a ~(30%) efficiency hit in cold weather.
Bottom line is for my R2 reservation my battery must be a large Pack or Max Pack with NMC chemistry.
evthree
Jason
Milwaukee, WI
I knew that coming in, and am generally happy with my purchase decision. Just trying to learn more specifics about how/why LFP underperforms NMC in cold weather as implemented by Rivian in the Gen 2 R1S. Thanks.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
Are you warming up your vehicle before you leave for a trip where efficiency matters that much (more than just some errands around town)? Even warming up the cabin while the vehicle is plugged in at home will warm up the battery a bit, helping out.
beatle
Springfield, VA
evthree
Jason
Milwaukee, WI
I warm cabin/seats ahead of time always, and sometimes have it plugged in (and charging/warming) ahead of a drive when I need the range. Mostly curious about apples to apples LFP vs. NMC.
