Conserve mode in Death Vally?
jn bot
jan
santa rosa ca
lotus ,z06,Subaru bolt
lawyer
When I drive through death Valley next week should I drive in conserve mode to keep The battery temperature is down? Will it keep the battery temperatures down?
PaythePiper
Phx AZ
Model Y, R1S Dual Max
Lmao. It’s hotter in Phoenix than Death Valley by 10 or more degrees. I’m fine here. You’ll be fine
CharonPDX
Charon
Cascadia
InfoSec Geek
Conserve mode won’t keep the battery temp down; but it will cause the front motors to get noticeably hotter than the rear. Leave it in all-purpose unless you’ll absolutely _need_ the extra range.
HaveBlue
The front motor is has a more efficient invertor which generates less heat. Basically drawing 100hp from just the front motor generates less BTU than drawing 50 from the front and 50 from the back. This is evident when doing long Regen in AWD or towing. The rear gets a little hotter for the divided work. Seems to be about 5% loss from my observation.
mkg3
R1S, Model 3, Outback, Artura
If you are asking this question how temperature affects range, here is an articles on the subject (yes reduces range for the single charge):
https://www.chase.com/personal/auto/education/maintenance/how-does-hot-weather-affect-ev-range
https://www.recurrentauto.com/research/what-a-c-does-to-your-range
If you are asking the question for the battery safety, it's designed to withstand much higher temperatures than weather would bring. Most critical components are designed with the factor of safety of 1.5x~2x so they are robust.
babock
Bruce
Los Angeles and South Lake Tahoe
2025 Rivian R1T, 2024 GMC Denali 2500HD, 2022 Hyundai SantaFe PHEV
Retired Electrical Engineer
Driving in conserve mode wears the inside of your tires. You should use conserve mode at a minimum.
BigSkies
R1T, Model Y
Conserve mode might be useful in Death Valley if you need the range. Use it for that, but not for temp concerns.
I drove through Death Valley east-to-west in All Purpose just fine, but there are trips that would stretch range capabilities a lot.
