Will your harness work with this 2025 charger? My truck is a 2022 R1T. Happy to test.. 2025 RIVIAN R1T CENTER CONSOLE WIRELESS PHONE CHARGING PAD OEM PT00590065F | eBay
The question is why would you want that $212+ obsolete pad instead of the one Rivian has just begun to implement into production… because the 2025 version is still not good enough? It is essentially the same as Gen1 with addition of that central divider and keycard reader for Gen2. Your phones won’t slide sideways as much, because of the divider, but could still slide fore/aft and out of alignment with the coils. This newest design has magnets, which make the pad compatible with Apple Magsafe and Android Qi2, to keep the phones aligned and in place. It’s also designed to accommodate phones with camera humps, which are partly to blame for the sliding (reduce contact area/friction and increased distance to coils).
sean_k
Sean
i would love some more details on the connector. would do this upgrade in a heartbeat.
breeves002
breeves002
Sam
St. Louis, MO
2023 R1S Quad
It seems Rivian already got more stock of the chargers if anyone was waiting. They’ve shipped me 4/6 that I’ve ordered already. Not sure when more will ship but their September estimate was very long luckily.
Edit: Right after I posted this I checked my email and they shipped the last 2 units so seems they may be back in stock.
Are the ones you have received or will be receiving spoken for?
SenatorSteak
Ron
Atlanta, GA
2026 R1T Tri-Motor
FYI just picked up my 2026 R1T and it does have this charging pad included. The magnetic grip is a nice touch and keeps my iPhone in place. I was worried I might have to get the TWraps pad but this appears to be much more useable than Gen2.
Rivian R1T R1S Gen 1 with Qi2 Wireless Charger Installed IMG_6402
That’s been known. The downside compared to aftermarket is charging speed. It looks to be capable of higher charging rates but doesn’t deliver it. To me, that isn’t a deal breaker, since that’s where my phone goes whenever I drive, regardless length of drive. So for my usage the pad provides a maintenance charge, much like a level 2 home charger vs a DCFC. And if I ever need faster charging there’s always the USB-C ports + cable.
twraps
Iliya
Concord
twraps.com
We will be releasing a Qi2.2 25W version of our pad, compatible with this gen3 console in the coming months :)
breeves002
breeves002
Sam
St. Louis, MO
2023 R1S Quad
In my testing it is a 20W charging pad. I did not test two phones simultaneously to see if it could do 40W combined. This is 20W before losses though. I would expect more like 15W into the phone. I kind of prefer this to higher power ratings due to heat. If I need to charge faster than that I can plug it into a 40w faster charger plugged into an AC port. Which I haven't needed to do yet.
Same. And might be better for battery health in the long run.
