Gen2 Quad
ebarneyr
Emerson
RS1 Quad reserved
Does anyone have any definitive info on whether the new Quad will have a Tesla type (NASC)port on the left rear as R2’s will? Or will that be a future update?
theonetruestripes
Josh
VT - North Eastern Kingdom
Tesla Model Y, for a few days before I “swap” it for an R1S
Programmer
FYI, Rivian.com’s R1S/R1T pages include the quad with zero info (everything TBA), except colors. Date listed as “coming 2025”.
I don’t remember seeing that before, but I could but utterly incorrect, I would have expected to see a more prominent announcement if it were new...
bmedfo1
Brad
2022 R1T launch edition 20" AT Carbon wrap
CFO
I dont know why so many care so much about this but from what I have read it is a good possibility. Me I would prefer it not change. I dont feel like changing my home charger or adding an adapter for every day use. What is so wrong with using the adapters we all already have for the few times a year we charge in the wild at a tesla station. If you are charging at tesla that often that this is a big deal you are probably paying more to charge than gas would be per mile.
theonetruestripes
Josh
Programmer
I’m not in the market for a new R1, so it is kind of moot to me, but if someone handed me a magic ticket “good for one R1” NACS would be one of the things I might wait for.
I had a Tesla before, and its charger is in my barn. I’ll move it back to the garage (and the garage one out to the barn). It is a physically nicer connector, as in it aligns easier. If you are “a little off” it seems to have some limited ability to self align, or maybe it is just a somewhat more flexible coord. The little button for the “open charge port door” likewise is “no big deal, but a fine detail”.
Around here the only reliable chargers are Tesla’s or Rivian’s, so it would swap which ones are convenient in the short term. In the long term I assume RAN will “do something” to make NACSs easy to use. Maybe converting all the chargers to duel tail, or licensing magic dock from Tesla.
So dealing with the change would be minor (on the other hand if I were keeping the “old” R1 and adding a NACSs R1 it would be modestly more complex because I would have to find a way to get a second charger in my garage, so a second 50A circuit, or get one of the EVSEs that have a set of lugs to attach another EVSE to...and buy a pair that know how to power share...and kick my TT out of the garage! Then again I don’t really have space for another vehicle...maybe I should pave path out to the barn so I can plow it in the winter and keep another vehicle out there...hey! Can you plow with an R1T?)
RivianRiverRat
Greg
Chattanooga TN
2022 Rivian R1T
Civil Engineer
Mygrain
Bloomington, IL
'22 IONIQ 5, '23 R1S quad, '21 Accord 2.0T, '03 GMC quadrasteer pickup
retired grain farmer, ex-Honda factory engineer
What color were the brake calipers on this supposed quad?
ebarneyr
Emerson
RS1 Quad reserved
ebarneyr
Emerson
RS1 Quad reserved
I have had Teslas since 2012. I am fortunate enough to have a second home in the high country of CO. I drive from CO where I am primarily based now ( I am now retired) to board meetings in MS several times a year. I am outdone with Musk and have a deposit on the new Quad. The shorter route I take currently has only a few old type( version 1) Tesla superchargers in spots where I charge…. unless the port is moved to the left rear on the new Quad… I see Rivans having to use 2 slots to charge at the old type V1’s which in time will not be a problem as more later versions of Tesla superchargers are installed. But…. Currently I prefer not to have to take up 2 charging spots. That is why I am interested if the port on the new Quad will be moved to the left rear. None of the Tesla personnel I have talked with at test drives of the Tri know the answer. I have Tesla wall mounted charger in one home and a 14/50 receptacle in the other…. So charging when I am not traveling is no problem.
Electrified Outdoors
Mount Airy, Maryland
Real Estate
I was just in Normal yesterday 😊 I will say that Rivian is very sensitive about photos inside the factory...must have been leaked.
an-thu-knee
Anthony
2023 R1T (Limestone)
the range to battery capacity doesn't add up - one of those seems wrong.
Jared2
New York
Wrangler Rubicon
Finance
Great specs! The two things I find disappointing is the range and charging speed. I was hoping for more from both. I assume the 355 range is in conserve. I live where there are fewer chargers and slower fast chargers once you get away from interstates.
I have to say, the main reasons I traded my Gen1 for a Gen2 were Range and Driver+.
I am thrilled with both, and while I'd LOVE to have a Quad again, I am likely just going to trade this one in for a Tri soon. Love my Dual Max Perf, but I can get the same 400+ mile range with the Tri in Conserve mode.
Range is key to me... I can make trips in my Gen2 that I never could in Gen1 without a stop.
Doug
Doug
Jackson, Minnesota
2021 Toyota Highlander Hybrid, 2002 Ford
Business Owner
Both of those reasons would benefit me to switch. I live right on I90 so hands free would be nice. I wondered how much the increase in range would benefit me. I do charge sometimes 30 miles from home just so I can make it. I am also struggling with which Gen 2 would be right for me. The Duel has the most range, but the tri or Quad would be much more fun.
roketdog
Reid
15759R0kitta
Rivian RS1, Tesla Model Y, Chevy Suburban
Range vs Speed. I had an EV with horrible range so I chose the Dual Max with Performance. It’s fast enough to get me around slow cars and range has been fantastic. I have AT tires so I could increase it even more with AS or similar tires.
All that being said - that Quad is going to be amazing!
KootenayEV
Andrew
Nelson, BC
R1T, Tesla Model 3
Environmental Engineer
Counterpoint - having it on the rear would SUCK for towing. I'd rather have it front passenger side (which would also work better for curbside charging).
