NDIrish
Gilbert, AZ
Engineering Operations Manager
Now if rivian would just add a hardware option for fingerprints scanner and a pin for locking the drawer. Many more options including gunsafe etc
At least a valet mode or set this to unlock based on driver profile.
But yeah a fingerprint/pin lock not attached to any profile would be safest
W1SE
Jake
Vancouver, WA
2022 R1T Quad, 2024 R1S Max
Branch manager
I wanted to make a Camp Speaker Drawer as OEM-looking as possible.
Does it lock like OEM speaker?
edit, I see it doesn’t. I see the one from twraps doesn’t either. This is when I will jump in. Once there is a fully sealed and lockable drawer.
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
This is really excellent, my dude! It looks like you're printing it in three parts, correct? I can only imagine the supports!
Hopefully you're not printing in PLA!
kozak79
kozak79
New Jersey
www.youtube.com
Visual Effects
Thanks! Supports aren’t bad. The middle has no supports, the back has minimal on the build plate, but the front has a bunch of supports inside. They popped out pretty easily though. Printing in PETG.
TR1GGER
Jason
Orlando
Nice work! Which reminds me that I need to take a look at that speaker. Had the car for abut 3 months and keep forgetting to use it. Cheers.
Similar issue....I keep forgetting about the flashlight
R1TCA
Florida
BMW R9T Scrambler
Nice work leveraging the 3D scan and getting it all scaled correctly!
kozak79
kozak79
New Jersey
www.youtube.com
Visual Effects
I am a novice at 3D printing and wondering what the drawback is to using PLA here? I have found it to be the easiest to print with.
PLA has a relatively low melting point. It will warp in a hot car.
PLA will deform considerably in a hot cab during the summer, so much so that it may become permanently stuck in the speaker cave.
You can prototype in PLA, but the finished build needs to be PETG or better.
IGR
I make things
PLA will start to get soft at 60 deg C, which is very much possible inside the car cabin,
also it is not UV resistant.
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Yup - a high quality PETG can be used. The issue is that some PETGs are not really high quality. They are a blend of materials that lower the glass transition temperature to something that doesn't work well for our application. Generally, I'm a big fan of anything that Polymaker makes.
ABS is better but is more susceptible to UV.
ASA is essentially ABS, but with better UV resistance.
Both of the latter two require an enclosure and filtration.
GrokTime
Sean
Ithaca
Toyotas
Ahh! That makes sense. Thanks!
IGR
I make things
+1 for Polymaker, I get the most consistent results with that brand.
Yw, its nice too see quite a few of us here are eager to help
