Navigating to a different charger
DenisRL
Denis
Mount Brydges
Ridgeline, Lexus 250 AWD
On a trip the Rivian planner selected a charger a few miles from the RAN charger I wanted to use. It would not even show the RAN charger on the map. How do you override the NAV?
josh0
Josh
Abiquiu, NM / Baltimore, MD
2023 (Nov) R1T, 2014 Jeep Cherokee
You can remove charging stops from the route, but if the one you want doesn’t show up on the map your best bet is probably to end navigation, and just enter the address of the one you want, then go back to navigating to your destination when you’re done charging.
DenisRL
Denis
Mount Brydges
Thanks. That’s what I did but left the original charger in the route planner to get the battery conditioning and then made the change as I got closer. Pretty silly process so I thought there must be a better solution.
Mellowyellow
You can also filter out different chargers to force the RAN station to show up and navigate there instead. It will pick it if there are no other options around. It was smart of you to keep the undesired charger in the nav to condition the battery before charging!
